Old 09-06-2016, 10:07 AM   #1
srqlegend
Default GS Spark Plug mystery
Hello!
I can't find any information at all on the
NGK PZR6E-11 or Nippondenso:PK20CR-11
what gives?
I've searched rock auto, ebay, amzn and came up with nothing.
From the Factory Service Manual pg. 4-4
GS Sedan/Coupe NGK:PZR6E-11 Nippondenso:PK20CR-11; For L and LS Model cars: Normal driving conditions NGK: PFR6G-11 PZFR6F-11 Nippondenso: PK20PR-L11 PKJ20CR-L11 ; Spark Plug Gap: 1.1 m m (0.04 in)
I'll probably use NGK V powers ( BKR6E-11) since I drive probably 4K miles a year.
Old 09-06-2016, 05:31 PM   #2
Those are very old part numbers which is why you cannot find them. They have been superseded by (NGK) PFR5G-11 and (Denso) PKJ20CR-L11
Old 09-06-2016, 10:58 PM   #3
srqlegend
Exclamation
Okay, I found this url with a bunch of NGK part numbers but still not the
PZR6E-11 that was superseded by the PFR5G-11.
NGK - Acura Legend Spark Plugs
Thanks,
Old 09-07-2016, 06:50 PM   #4
Get the 6 heat range About 10.00 HERE AT AMAZON (PFR6G-11), they work fine. Same as you would pay 16-20.00 each for at the dealer. HERE is a broader amazon search that has a 5G heat range in the results.
Old 09-15-2019, 02:19 AM   #5
srqlegend
Cool
Digging around on rockauto, ngk, denso
Strangely rockauto shows NGK plugs in the 6 heat range (5 hottest for NGK)
but for Denso it shows 16 (hottest in their range) instead of 20 that our FSM calls for.
NGK 5555 PFR6G-11 Laser Platinum series
Manufacturer Heat Range 6
the Denso model:
3247 ( PKJ20CR-L11 )
Manufacturer Heat Range 20
If you look up Acura Legend on the Denso site they only pull up heat range 16 plugs even though they have the 20 heat range ones too though the only way to find those is to cross reference the 5555.
Now I feel silly for spending 1.5 hours doing this.
Spark Plug SK Legend 2nd Gen. Legend General Discussion 6 10-07-2014 04:57 PM
Spark plug sdgayoon 2nd Gen. Legend General Discussion 23 05-13-2012 03:21 PM
Ever have your spark plug wire fly off spark plug?!! Fred Clark 1st Gen. Legend General Discussion 9 01-04-2011 01:27 PM
Spark Plug Nevada Ray 1st Gen. Legend General Discussion 25 07-19-2010 09:20 PM
spark plug HUH? daveCFPrez 2nd Gen. Legend General Discussion 23 04-29-2010 08:23 PM
