Old 09-20-2011, 06:45 PM   #11
Logistics
Logistics is on a distinguished road
:facepalm: I almost posted that there was "no information about spark-plug wires!"
Logistics is offline   Reply With Quote
Old 12-13-2012, 07:24 AM   #12
vayankee
vayankee is on a distinguished road
Default Question about Legend maintenance
I noted the following line under regular maintenance in your very helpost post:
"Adjust valve clearances."
We have two legends, both sedans-a '92 and a '94. The '92 has 150k on it, and there is what I and a mechanic friend think is valve noise. I looked through the online service manual under valves and could not find anything about adjusting them. I realize that they are hydraulic valves. But the item above about adjusting them and the noise has me puzzled.
Is there something else that could sound like noisy valves that needs attention on the '92? The '94 with over 125K does make that sound.
Thanks.
vayankee is offline   Reply With Quote
Old 12-13-2012, 07:38 AM   #13
Thanks.
The schedule in this post comes from the Haynes manual, which covers both the Legend and the Integra, and on top of that it doesn't follow the recommendations from Honda anyway. Haynes uses basically the same schedule for every car. There are no valve clearances to adjust on the Legend. The wiki has an accurate Legend-specific maintenance schedule: LegendWiki - G2: DIY: Maintenance
Your lifters are probably the cause of the sound, and it's very common. Others may suggest different oils and additives, but the only real "fix" is to remove and bleed them all, but that's a lot of work just to quiet down a sound.
Old 12-13-2012, 09:24 AM   #14
vayankee
Your lifters are probably the cause of the sound, and it's very common. Others may suggest different oils and additives, but the only real "fix" is to remove and bleed them all, but that's a lot of work just to quite down a sound.
Live with it then-sounds good. Thanks for your help!
Old 12-15-2012, 06:51 AM   #15
SXCAL
Bust A Move
SXCAL's Avatar
Real Name: Conner
SXCAL is on a distinguished road
Lmao hgeez:
http://proformancespecialties.com/Home.php
Proformance Specialties Machine & Fabrication Shop.
Why follow the trends? Legends didn't become Legends that way.
ppl want em, no one really ever has any money thou and shipping is a bitch. pretty much sums up legend life
SXCAL is offline   Reply With Quote
Old 09-27-2013, 11:28 PM   #16
Akrite
Akrite is on a distinguished road
Is there some something that can visually walk me through changing out the thermostat?
Akrite is offline   Reply With Quote
