Old 04-04-2011, 07:57 PM   #41
Originally Posted by soloist View Post
Important Question below:
Ok, going out on a limb here but, other than maintenance of the EGR system and a PCV oil catch can, just wondering if an auxiliary EGR flow detection system could be integrated into the the Legend ECU, something that could trip Code 12 by using a sensor that uses the same range of voltage as the EGR valve lift sensor. Perhaps that could be tied in together or used instead of that particular sensor. That way at least the EGR compensation maps would be bypassed appropriately, to PREVENT damage.
Holy long post batman, thanks!
Just from thinking about it, the algorithms that would be used to check for EGR flow without a false positive would be enormous! It would be nearly impossible to implement something like that within the ECU considering its lack of free space and the sheer number of variables that are encountered. It would actually be more feasible to make an internal "test" in where the EGR is commanded on briefly on occasion and changes to intake vacuum and/or idle are monitored.
P.S. Thanks for the word that was on the tip of my tongue yesterday when I was writing that - "herniated". I changed it from "smooshed" lol.
Old 04-04-2011, 08:17 PM   #42
I'd like to add one more important fact here that may seem obvious to some. If you have a clogged EGR valve and aren't able to clean right away, or you have the EGR deliberately blocked, disconnect the lift sensor. Yes, you'll get a CEL but you wont risk damage from running the compensation maps. In the future I may offer the ability to disable the EGR and the compensation maps with a chip - but for now I just don't have the time to do them.
Old 04-04-2011, 09:10 PM   #43
BluBrett
Real Name: Brett
Send a message via Skype™ to BluBrett
Thanks for the answers! I guess tomorrow I'm going to ask my engine swapper if the EGR valve was cleaned at the time of the swap. How long does it generally take for a person to remove, clean, and put the EGR back in?
Previous | 1995 Legend Sedan | Canterbury Green | Type E
Current | BMW M240i | Mineral White | Coral Red
Old 04-04-2011, 09:19 PM   #44
Originally Posted by BluBrett View Post
Not trying to be a jerk and prove you wrong, considering I know nothing about engines or how they break, but:
BHG #1: ~130,000 miles. Engine repaired.
BHG #2: ~195,000 miles. Engine swapped.
ALL scheduled maintenance was done (doesn't say EGR was cleaned, but says 30K, 60k, 75K, etc. services were performed), so unless the dealership was incompetent/ ripping me off, the EGR was inspected/cleaned as it should have been. Or maybe I just had a bad engine? Any other ideas as to why my HG's kept blowing?
Edit: Also, let's say someone has a 250,000 mile Legend that hasn't had BHG before, but the EGR had never been cleaned or inspected. If they were to clean their EGR and nothing else was about to cause BHG, would that prevent a BHG, or would the damage already be done?
Only some dealers and garages do regular EGR service.
I recently went through some paperwork for a 97RL and noticed that Southern Motors (Savannah, GA) and Ed Voyles Acura (Chamblee, GA) did regular EGR service to that car (looked like Matt's 60K recommendation).
Many customers will not purchase the upsales and that's where EGR services get skipped. They are not cheap and don't fit into most customers' "if it ain't broken don't fix it" mentallity. In this case broken may be the BHG. Though the service gets recommended and passed up by many, a failed NOx on the EMI will bring a car back to the shop for the cleaning.
Matt, I appreciate the time and thought you put into this thread. I believe the BHG scare and frequency we see needed to be addressed with cause and responsibility. Most BHG prevention responsibility really does ride on the car owners. The shops have become sensitive to Honda's 3.x carbon/EGR issues but too many customers fail to heed the call and shops are scared to push it and come across as thieves.
Pay me now or pay me later I used to always say... "now is cheaper."
Old 04-04-2011, 09:51 PM   #45
Nino418
3.5 Hybrid Powered
Nino418's Avatar
Real Name: Ze Nurse
Its not just the egr pipe, its the whole manifold. Its a job that will take a few hours if done properly.
R.I.P
Old 04-04-2011, 11:27 PM   #46
BluBrett
Real Name: Brett
Oh, then that was most likely done when my engine was swapped. That was about 30K miles ago, so I should still have 30K to go?
Old 04-05-2011, 01:51 AM   #47
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
just because the engine was swapped, doesn't necessarily mean that they took the time to check or even clean the egr passage...just food for thought
Old 04-05-2011, 03:09 AM   #48
this is a super read matt!
It would be really cool to see how EDM/JDM legend compare to this egr problem, since we run higher octane fuel. I guessing running low grade fuel will only hasten the egr problem
Old 04-05-2011, 06:14 AM   #49
Anyway, fantastic job by you (and Q if he helped with this part)
I don't believe I had anything to do with it, but thanks for the honorable mention anyway!
Old 04-05-2011, 06:36 AM   #50
excellent write up. rep'd
Did the MLS head gaskets ever happen? thein 2nd Gen. Legend General Discussion 20 02-11-2011 05:46 AM
My Head Gaskets the_professional 2nd Gen. Legend General Discussion 9 08-11-2010 12:10 AM
Felpro head gaskets masterblaster 2nd Gen. Legend General Discussion 10 07-16-2010 10:04 PM
Used head gaskets blackeagle229 2nd Gen. Legend General Discussion 16 03-31-2010 02:17 PM
head gaskets? 90LSCoupe 1st Gen. Legend General Discussion 2 08-18-2009 10:11 PM
