Old 04-03-2011, 08:19 PM   #21
Nino418
3.5 Hybrid Powered
Nino418's Avatar
Real Name: Ze Nurse
Originally Posted by Tippey764 View Post
Are there legends in other markets without the EGR system like the g1's?
Yes there are... i just forget which market it is. I think its the Australian market.
R.I.P
Old 04-03-2011, 08:26 PM   #22
Tippey
Pony
Tippey's Avatar
Real Name: Austin
so then if this theory was true then that market of cars would not have BHG
also you could take the ECU from one to delete the egr maps?
Old 04-03-2011, 08:28 PM   #23
Yes, I have the chip from the OZDM (Australian) market and guess what? They run lower compression (9.0:1), they use REGULAR gas and a much, much more reserved ignition timing map.
Without going into technical detail, there is a switch within the program that turns off all EGR operation, and this switch is OFF in the OZDM ECU. Reverse engineering this program switch is actually what allowed me to discover many of my findings. It provided enough information in order for me tie up this theory with enough facts to support them.
P.S. Thanks for reminding me about the OZDM chip, I will edit the OP to include a blurb about it.
Old 04-03-2011, 08:46 PM   #24
Isn't the firing order 1-4-5-2-3-6?
*edit* that was supposed to be 1-4-2-5-3-6, I put the 2 and 5 backwards
Old 04-03-2011, 08:47 PM   #25
Vic Cardenas
Vic Cardenas's Avatar
In a place you might not expect to find it... Ok now find the firing order . Also, I fixed the original post with cylinder #3.
I have a crappy Haynes manual sitting in front of me.
It says firing order is, 1-4-2-5-5-3-6
it literally says this with two 5's
AutoAlchemist.com
Old 04-03-2011, 08:50 PM   #26
so basically from your big post (didn't read all the other ones) if we were to either block or delete the EGR system that might help the c32s? but it seems what your saying is the egr is needed to help prevent detonation cause we have a "high" compression engine.
in a "shortened" version of what your saying. reason I'm asking is because kenso ran a catchcan for years on his legend, and other have egr block plates installed. so maybe ask them how/if they have a BHG
Old 04-03-2011, 08:58 PM   #27
Vic Cardenas
No, he's saying if the EGR is blocked, it will cause detonation because the gasses help cool the cylinder. There's a map that is running advanced timing and leaner fuel trim only when the EGR valve opens, even if the EGR system is blocked up. If the gasses are blocked...ping, ping!
AutoAlchemist.com
Old 04-03-2011, 09:03 PM   #28
Reboticon
Lord Of The Clunker
Reboticon's Avatar
Yep Vic explained it correctly, and nice job finding the cylinder numbers. I'm just glad to know I'm not crazy because they have all been rear passenger side for me.
Old 04-03-2011, 09:26 PM   #29
yeah sorry thats what I ment going on little sleep today...
So with the exhaust gas being cooler then combustion chamber gases its causing the cylinders to "cool" so.... run a hypothetical question here.
if we ran say a cryo kit in the intake manifold to keep the air temps cooler, wouldn't that help do the same as a egr? Or would the durastic difference in temps actually damage the gaskets. For this scenario, lets say EGR gases are 1000F and combustion chamber is 2500F and cyro kit is 100F. I ask because then those running NOS won't blow hg's (if they ran it daily 24/7)
if that doesn't make sense I'll retype it in the AM and explain it better. I'm basing this off of other cars that ran high compression in the early 90s (10:1) but they don't BHG, but their cooling system is setup differently then ours.
Old 04-03-2011, 10:26 PM   #30
Of course reduced air intake temperatures directly reduce combustion chamber temps! What do you think the point of an intercooler is on any turbo car?
Most likely those cars you're talking about don't have the same type of EGR compensation that the Legend does.
Did the MLS head gaskets ever happen? thein 2nd Gen. Legend General Discussion 20 02-11-2011 05:46 AM
My Head Gaskets the_professional 2nd Gen. Legend General Discussion 9 08-11-2010 12:10 AM
Felpro head gaskets masterblaster 2nd Gen. Legend General Discussion 10 07-16-2010 10:04 PM
Used head gaskets blackeagle229 2nd Gen. Legend General Discussion 16 03-31-2010 02:17 PM
head gaskets? 90LSCoupe 1st Gen. Legend General Discussion 2 08-18-2009 10:11 PM
