Old 03-26-2010, 11:25 AM   #31
lgnd
EDM KA8 owner
lgnd's Avatar
Real Name: Istvan
lgnd is on a distinguished road
Great info! As a side note aftermarket front upper control arm bushings have different diameter than oem. That's my experience when we tested our product in various control arms.
lgnd is offline   Reply With Quote
Old 03-27-2010, 05:30 AM   #32
phystein
phystein's Avatar
phystein is on a distinguished road
Send a message via MSN to phystein
Omg that is some awesome info! What year sonata is that from?
1999~2005 model.
Part # 54443-38600 or 54443-38000
phystein is offline   Reply With Quote
Old 03-27-2010, 06:30 AM   #33
phystein
phystein's Avatar
Default Beam bracket bush
1999~2005 hyundai sonata bush.
part # 54584-38100
It need grinding at inner side but outer side is almost same.
We can use it for Radius bush too and It need some spacer washer..
Old 03-27-2010, 09:26 AM   #34
DSL
'93 3.5 type 2 coupe
DSL is on a distinguished road
wow... i will try this soon. thanks. just called my parts store.. they quoted me 10 bux each!!! 20 bux each at the dealer. If this works, thanks PHYSTEIN!!!
'01 3.5l rl engine- 6 speed, type2- cams, valve springs/retainers, and intake manifold.
ground control, koni, addco-front & rear, 18" volk III
rm racing intake, gasket match ported exhaust manifold
DSL is offline   Reply With Quote
Old 03-27-2010, 10:43 AM   #35
WhyteLegend
3.52..
WhyteLegend's Avatar
WhyteLegend is on a distinguished road
very interesting
KA7 3.5 TII 6spd LSD + more,95 KA8 3.5 LS , KB1 H&R Springs, 09 Rear Sway Bar, CAI, 20" Giovanna
http://i33.photobucket.com/albums/d88/mark2000jm/AC-RL1.jpg
WhyteLegend is offline   Reply With Quote
Old 04-08-2010, 12:45 PM   #36
DSL
did you machine the diameter down too? i measure the legend part at 65mm.
Old 04-09-2010, 10:19 AM   #37
phystein
phystein's Avatar
No, I didn't.
I have just pressed it without grinding.
You need special tools to press bush.
Old 04-09-2010, 10:51 AM   #38
Old 04-09-2010, 11:17 AM   #39
alittlethin
alittlethin's Avatar
alittlethin will become famous soon enough
You could easily take that much material out of your arm with a emery flapper wheel.
You could then set your new bushing with 680 green, bearing rated Loc-tite.
Trust me it won't come out unless you have a torch.
special tools needed = drill & hammer
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it??
Come on man, don't take it so serious. It takes a lot of comitment and pride to throw money into something that will never yield a 16th back.
~Dv8
alittlethin is offline   Reply With Quote
Old 04-09-2010, 11:18 AM   #40
very interesting.
Driver side upper Control arm Roger OEM Parts 3 10-24-2009 01:13 PM
Front Upper Arm torque specs Roger 2nd Gen. Legend General Discussion 0 07-19-2009 07:47 AM
Right upper A control arm Roger OEM Parts 0 07-12-2009 09:17 AM
New rear control arm creeking Roger 2nd Gen. Legend General Discussion 0 06-29-2009 06:27 PM
Rear control arm custom bushings lgnd 2nd Gen. Legend Performance Enhancements 8 06-19-2009 11:52 AM
