Old 11-04-2009, 09:38 AM   #21
Roger
Roger's Avatar
With the right lube they can go a few years before squeeking
Old 11-04-2009, 09:58 AM   #22
The-Teej
The-Teej's Avatar
The-Teej is on a distinguished road
that's what she said, I couldn't help it, sorry
"Ka8e" 201HP & 190 Torque... Still in progress
The-Teej is offline   Reply With Quote
Old 11-04-2009, 02:44 PM   #23
onthe3rdday
onthe3rdday's Avatar
onthe3rdday is on a distinguished road
What about delrin? I'll elaborate when I have more time BUT... "Family Man" from the other site has the sketch for that bushing. Delrin is pretty much maintenance free and it's perfect for when you want to precisely locate something like a control arm...
Found it
http://www.acura-legend.com/vbulleti...frame-bush.jpg
onthe3rdday is offline   Reply With Quote
Old 11-04-2009, 03:28 PM   #24
lgnd
EDM KA8 owner
lgnd's Avatar
Real Name: Istvan
lgnd is on a distinguished road
Front polyurethane bushings are done
lgnd is offline   Reply With Quote
Old 11-04-2009, 03:30 PM   #25
Legend95
KA7 MANIAC!
Legend95's Avatar
Legend95 is on a distinguished road
Have you ever driven a Legend with bad lca bushings? There is absolutely no steering return, its downright dangerous if your not on point. My goal is to find something better than stock but still daily driver material.
could you describe it easier?
what happens when it's bad?
Legend95 is offline   Reply With Quote
Old 11-04-2009, 05:30 PM   #26
antik
I blame the M3.
antik's Avatar
Found it
Delrin is HARD. Zero deflection, harder than poly hard. It's not appropriate for suspension bushings in my opinion. It's commonly used in things that need very minimal damping or areas where you can tolerate a bit of extra NVH. Case in point, the BMW crowd uses them for things like clutch pedal arm bushings, gear selector carrier bushings, and one loony used it for a flexdisk (damper between transmission and driveshaft) despite the warnings of the community for a very short period of time until he too agreed it's too hard for anything but maybe a track car.
You want SOME deflection in that bushing. Stiffen it up too much and you're defeating the purpose of a bushing. The suspension is intended to move a little.
Also, considering this is something that's a marketable solution in replacement of the stock (read: SOFT) solution, Delrin is not something many customers will get onboard with.
'95 Auto L Sedan [SOLD]
Old 11-13-2009, 08:29 AM   #27
buzzard
buzzard is on a distinguished road
I posted this on the last forum and it was not received well. Lets try again
htthttp://www.bmsc.com.au/forums/rallying-technical/11303-solid-engine-mounts.html#post115665p://
enginemounts.pdf is what you are looking for, post #27.
Chris
#1 in Honda C32A engines worldwide.
The innovators, not the imitators.
buzzard is offline   Reply With Quote
Old 03-26-2010, 03:25 AM   #28
phystein
phystein's Avatar
phystein is on a distinguished road
Send a message via MSN to phystein
Default almost same size bush.
We are using the bush of hyundai Sonata in korea.
After grinding 1.6 mm
phystein is offline   Reply With Quote
Old 03-26-2010, 03:40 AM   #29
Omg that is some awesome info! What year sonata is that from?
Old 03-26-2010, 04:09 AM   #30
-X-
GS MAXXX
-X-'s Avatar
Send a message via AIM to -X-
The information and discoveries you share are always full of win, thank you!
Driver side upper Control arm Roger OEM Parts 3 10-24-2009 01:13 PM
Front Upper Arm torque specs Roger 2nd Gen. Legend General Discussion 0 07-19-2009 07:47 AM
Right upper A control arm Roger OEM Parts 0 07-12-2009 09:17 AM
New rear control arm creeking Roger 2nd Gen. Legend General Discussion 0 06-29-2009 06:27 PM
Rear control arm custom bushings lgnd 2nd Gen. Legend Performance Enhancements 8 06-19-2009 11:52 AM
