Old 11-03-2009, 01:20 AM   #11
Originally Posted by bl420 View Post
im not disagreeing with you... any sort of caster changes will affect steering return... which is why i asked what is so bad about a bushing that can deliver zero deflection?
stock specifications for caster is 345' which is positive... and as long as it remains within spec a bushing that is more solid wont affect steering return negatively. the "springiness" of the bushing has little to do with steering return is basically what i was trying to get at.
just take a look at what tractions bars do. many of them use spherical bushings for their radius rods.
i hope you're not taking my posts the wrong way... im just here to help.
I need a solution for replacement control arm bushings I can sell my customers instead of the $500.00 each brackets from the dealer. I'd like them to be better than stock without the maintenance issues of poly bushings. Your starting to loose me here.
Old 11-03-2009, 01:26 AM   #12
bl420
bl420 is on a distinguished road
the only thing i was giving you was another option since it seems you've closed the doors on poly bushings... its as simple as that.
bl420 is offline   Reply With Quote
Old 11-03-2009, 01:29 AM   #13
Haven't closed the door, the free floating bushings are just not for me. What was this other option? A cast poly bushing? Any suggestions on what hardness to use and what would make it REALLY stick to the sleeve?
Old 11-03-2009, 01:49 AM   #14
bl420
well im just suggesting polyurethane because i believe it will be easier to cast vs rubber
as far as rockwell rating i have no idea... it would be best to get a durometer to test out what the stock bushing is rated at.
to make urethane stick to the sleeve better you can use something called URE-BOND
Old 11-03-2009, 03:44 AM   #15
Matt you make them and I'm IN.
+1. You make, I buy.
Old 11-03-2009, 05:16 PM   #16
antik
I blame the M3.
antik's Avatar
Great idea Matt. I'm confident a lot of us could benefit from a cost effective solution here. If the cost is reasonable, I think I'd be down.
'95 Auto L Sedan [SOLD]
Old 11-03-2009, 05:23 PM   #17
whats77inaname
Not forgotten.
whats77inaname's Avatar
Poly units are pretty sweet.
Old 11-03-2009, 05:26 PM   #18
Roger
Roger's Avatar
How about some pics of which bushings we are talking about exactly the one the suspension fork hooks to on the lower control arm?
Old 11-04-2009, 07:50 AM   #19
Poly units are sweet, if you're a mechanic. Imagine me installing a set for a customer and 3 months later them coming back "THEY'RE SQUEEEEEEEEKING I WANT MY MONEY BACK".
Old 11-04-2009, 08:18 AM   #20
antik
I blame the M3.
antik's Avatar
The BMW guys run 'em all the time without added noise. It can be done with the right lube.
I'm also not following why you're so adverse to poly: not complaining, I'm fine with rubber. Any solution that can be created is a good one in my book.
Driver side upper Control arm Roger OEM Parts 3 10-24-2009 01:13 PM
Front Upper Arm torque specs Roger 2nd Gen. Legend General Discussion 0 07-19-2009 07:47 AM
Right upper A control arm Roger OEM Parts 0 07-12-2009 09:17 AM
New rear control arm creeking Roger 2nd Gen. Legend General Discussion 0 06-29-2009 06:27 PM
Rear control arm custom bushings lgnd 2nd Gen. Legend Performance Enhancements 8 06-19-2009 11:52 AM
