I was wondering if anyone has had one of these built for their car? If so who was commissioned to do the work. Are you happy with the results?
Sent from my SM-G930T using Tapatalk |
#2 | |
![]() Quote:
Would you consider getting a cheap spool gun Aluminum MIG welder and messing around with it yourself? I have been welding mild steel for 20 year but just started welding aluminum 2 years ago with this. I'm amazed at the results so far, but then again, I haven't tested anything I've welded yet that needs to be leak proof. ![]() |
is building things
um.....
I created a high volume short runner using existing manifold that maintained the usaged of the low-end VISS flap for my turbo project yearssss ago.(also ran it NA for a while) Dv8 created one of similiar design. The only fully created one from scratch was Greekpower. What is odd is that the runner length in the end was probably the same length almost is the OEM. He wanted longer runners for more torque. He had a tapered main body which was smart. In the end there is no point whatsoever for money spent unless you are doing some major work.
"I never teach my pupils. I only attempt to provide the conditions in which they can learn. " Albert Einstein (1879 - 1955) |
Can you describe what you did with your manifold or post a link or picture? When I had mine apart I considered several ways to simplify things but couldn't really figure out an elegant way to make any improvements. On a T2, at least, I don't think you can really eliminate the middle section. I looked at cutting into the top section and moving the throttle body up toward the top, but I didn't want to cut out all the passage ways. In the end, I just removed all the butterflies and cut out a couple of the hinge sections for them. After flipping it front to back I wouldn't be able to fit the diaphrams anyway, because of interference with the coolant passages, even though I had to rebuild the coolant crossover pipe and heater pipe system and thermostat housing.
#5 | |
is building things
![]() Quote:
Here above
How much does the midrange suffer when the air flaps are removed? We use custom intakes on the race engines, but my experience shows that road car engines are always better with the flaps operational.
#1 in Honda C32A engines worldwide. The innovators, not the imitators. |
#7 | |
![]() Quote:
I plan to run about 5psi boost and hope to get to about 300 chp with a stock T2 long block. That would get me to right around 7lbs/chp, kinda close to Hellcat territory. Of course it's all just BS at this point, but I have made some progress. |
#8 |
Off road racing.No way, the C series party is just getting started.I thougt Swift or JConrad might know the answer.
C32A with aftermarket rods 8:1 comp single turbo about 12psi https://www.youtube.com/watch?v=kdue3MLYMoc
#9 | |
![]() Quote:
#10 |
Thats not my build, just a guy who used a C32A in his off road car. Most guys here use the Albins AGB transaxle. My involment in that car was doing the egine management setup and tuning, and we dont use OEM Honda ecu.
FS: type 2 intake manifolds | GreekPower | OEM Parts | 1 | 08-28-2013 08:00 AM |
Sheet Metal Arch molding rear | billthomas | 1st Gen. Legend General Discussion | 3 | 05-28-2012 09:10 AM |
FS: 2 3.5 rl intake manifolds | Jonslegend | OEM Parts | 11 | 12-20-2011 12:34 PM |
FS: Type II intake manifolds | Ken | OEM Parts | 10 | 09-27-2010 06:31 PM |
FS: Type II and RL intake manifolds + more | soloist | OEM Parts | 1 | 08-20-2010 12:29 PM |
