Old 10-27-2017, 07:30 PM   #1
jaconrad1
Real Name: Joseph
jaconrad1 is on a distinguished road
Default Type I cylinder head build
I was wondering if anyone has had there heads build? Valves, springs, 3 angle valve job, milled, ect.. I wanted to know approximately what it costs, and what your horsepower gaines where? Trying to see if the results justify the means
Sent from my SM-G930T using Tapatalk
jaconrad1 is offline   Reply With Quote
Old 10-27-2017, 09:36 PM   #2
I did long ago and are redoing them now...
If your not going to drop the money for custom valves (1100) springs (100) port and polish (400) and some cams (400) your not doing much
Old 10-28-2017, 05:49 AM   #3
jaconrad1
Real Name: Joseph
So for the 2500 you spent on them what would you say your performance gains Where? Just curious
Old 01-03-2018, 11:21 AM   #4
buzzard
buzzard is on a distinguished road
Standard the heads flow fairly well. T2 heads are the clear choice if you can get them. A good 3 angle seat and valve re-face from a race shop is all you need. We use a race shop in Sydney that only does heads. Every time the heads or block are milled the cams will retard. This is not good as the cams are quite retarded stock. You need better springs if you want to rev it higher.
#1 in Honda C32A engines worldwide.
The innovators, not the imitators.
buzzard is offline   Reply With Quote
Old 01-03-2018, 11:35 AM   #5
buzzard
The standard Honda valves are made from very good material with very good heat treatment. The only reason I can see for custom valves is, you are moving to larger diameter valves. The Honda valves have proven durability for N/A and turbo endurance race applications.
is this cylinder head reusable? (bad pitting) LSATYD 1st Gen. Legend General Discussion 11 07-16-2013 06:56 PM
weight of T2 cylinder head devolution 2nd Gen. Legend General Discussion 5 11-24-2012 08:08 PM
Need head cylinder bolts uniquelegend 1st Gen. Legend General Discussion 6 04-18-2012 06:04 AM
Learn Me Some Cylinder Head blackfocal 1st Gen. Legend General Discussion 2 08-29-2011 12:42 PM
Cylinder Head Porter AyeJay 2nd Gen. Legend Performance Enhancements 2 06-09-2009 12:18 PM
