Old 03-22-2017, 04:50 AM   #1
jaconrad1
Real Name: Joseph
jaconrad1 is on a distinguished road
Default performance fuel injectors
I am thinking about purchasing some performance fuel injectors from rc engineering for my 91 legend sedan. Has anyone installed these? I was thinking of upgrading to 370 or 440 cc injectors. Besides having my ecu adjusted is tlhere any other things that may need to be done to make them run correctly in the car?I also will need to up the pressure coming out of the fuel regualtor as well? Need some insight thanks
jaconrad1 is offline   Reply With Quote
Old 03-22-2017, 06:28 AM   #2
What mods do you have that have you looking at injectors? Legends run rich from the factory so there's no reason to change injectors unless you've done a lot of mods and even then.. 100 bucks gets you a set of 360 (3000gt) or 125(turbo dsm) rc injectors suck
Old 03-24-2017, 10:24 AM   #3
jaconrad1
Real Name: Joseph
thanks for the info bro.
Old 03-24-2017, 02:46 PM   #4
buzzard
buzzard is on a distinguished road
T1 engine runs 2.75 Bar base fuel pressure, T2 runs 3.0 Bar. Experience tells me that a stock 3.2 does not need an injector upgrade. What it needs is more airflow and higher valve spring seat pressure, so you can rev it more.
#1 in Honda C32A engines worldwide.
The innovators, not the imitators.
buzzard is offline   Reply With Quote
WTB: Fuel injectors 91 ka8 hoodlikegaza OEM Parts 1 08-22-2015 06:31 PM
Fuel Injectors for Type 2 92coupeType2 OEM Parts 12 04-29-2013 10:09 AM
Fuel Injectors Donald 2nd Gen. Legend General Discussion 8 10-28-2011 06:31 PM
FS: Fuel Injectors for Sale killaswa6 OEM Parts 1 11-15-2009 09:19 PM
fuel injectors Biggg72 2nd Gen. Legend General Discussion 17 06-19-2009 10:25 PM
