Old 04-23-2015, 08:13 AM   #21
Aking
Aking's Avatar
Real Name: A King!
Originally Posted by 013Reaper View Post
They are about 500 plus tax...I'll see if I can locate the part number but it isn't to hard to find on Google, also keep in mind that there are two versions a sport and a higher Tier model. The sport is adjustable but it only allows dampening (rebound) whole the other allows for adjustment on both compression and rebound which is the set I have. Both allow for a 1-3" drop in height, the fully adjustable units are about 600 and tax.
Can you post a link where I can find these? Also, do they come as an assembly with the spring and strut? I do not want to kill myself trying to use a spring compressor.
Old 04-23-2015, 09:07 AM   #22
LegendarySE
Just some Leftover L
LegendarySE's Avatar
LegendarySE is on a distinguished road
Originally Posted by T-Clyde View Post
Using different forks does not make it a hack job. Cutting springs is a hack job.
I stand corrected
01' 3.5 104k, 5sp MT 144k, car itself 138k. 12/12/12
LegendarySE is offline   Reply With Quote
Old 04-23-2015, 10:03 AM   #23
whats77inaname
Not forgotten.
whats77inaname's Avatar
There's a way to remove stock springs on the car w/out using a compressor if you're feeling froggy. I've done it multiple times w/out issue. That being said, do it at your own risk.
https://www.youtube.com/watch?v=3ikPsNtzHHo
Old 11-02-2015, 08:34 AM   #24
Qs91Coupe
Qs91Coupe's Avatar
Real Name: "Q"
Qs91Coupe is on a distinguished road
Which did you go with Aking?
"Out with the old and in with the new." 3.5 hybrid 5MT LS
Check out my 4 sale thread:Click here!!
Qs91Coupe is offline   Reply With Quote
Old 11-08-2015, 10:15 AM   #25
PandaRescue89
Noob
PandaRescue89's Avatar
PandaRescue89 is on a distinguished road
Wait... We have two versions of the koni shocks? I've only ever seen the Reds where you can adjust the rebound....
I feel jipped! Link to the higher end model?
Heroes get remembered but legends never die - The Sandlot
PandaRescue89 is offline   Reply With Quote
Old 11-08-2015, 06:34 PM   #26
legend921
Real Name: Legend Addict
legend921 is on a distinguished road
There is only one model to the Konis which is just the Reds. They used to have the spring and shock combo that was painted a different color utilizing the eibach springs but that is the difference.
legend921 is offline   Reply With Quote
Old 09-20-2018, 07:28 AM   #27
Zachari86
Zachari86's Avatar
Zachari86 is on a distinguished road
How does this work on the legend touring? Since it's running Honda Progressive Damper suspension system?
Sent from my SM-G955F using Tapatalk
Zachari86 is offline   Reply With Quote
Old 09-20-2018, 10:48 AM   #28
Okay so I checked your pictures and see your trim level JDM trim vehicle. I am though about this part of your statement. Unless some prior owner went through a lot of trouble converting the suspension you should have the standard spring and strut assembly these cars were engineered with by Honda/Acura. Our suspension changes/upgrades are pretty limited and basic. OEM style replacement struts (KYB makes them for Honda as OEM replacements now) or a Koni strut and separate spring setup, or a set of coil overs (or air bag system) of which K-Sports are the most common. The question is how do you want your car to ride should you NEED to replace your suspension. I have done KYB OEM replacements as well as Koni reds and lowering springs. My next suspension replacement is likely going to be K-Sport coil overs.
Old 09-24-2018, 07:46 AM   #29
Juicemon
Juicey
Juicemon's Avatar
Juicemon is on a distinguished road
Send a message via AIM to Juicemon
So yea even ive been shopping around. I'm not even interested in lowering my car but theres really no other choice for a fully loaded option it seems. And buying the kyb struts then sourcing oem springs which I cant seem to find anyway looks like it'll cost just as much if not more and then as mentioned the headache of compressing springs. If there is a fully loaded coilover option for around 5-6 i'd really be considering it as all ive found is in the neighbourhood of a grand. Or the group buy. we get sets for around 5-6 i'd need atleast 2.
lets get some links to these 5-600$ sets because I cant seem to find em!?
Edit: wasn't paying much attention...lol this is super old thread... so ignore most of what I said besides where are these more affordable options?
Juicemon is offline   Reply With Quote
Old 09-25-2018, 01:07 PM   #30
Hockeyman
Real Name: Blake
Hockeyman is on a distinguished road
You could run 98-02 Accord coilovers with the proper forks, Raceland and Truhart are super cheap, probably ride like it too.
Hockeyman is offline   Reply With Quote
Suspension Round 3: D2 Coilovers installed Nick Second Gen Legend Gallery -- 1991 - 1995 13 01-05-2015 09:23 PM
Airbag suspension options?? rprojas6 2nd Gen. Legend Performance Enhancements 11 09-25-2013 12:55 PM
Coilovers, Shocks, and Strut Suspension. B+O Wheels & Tires 1 08-18-2011 10:51 AM
OEM spg rate / Ebay Coilovers, Accord, TSX, Prelude or other Suspension? wadd3456 2nd Gen. Legend Performance Enhancements 2 01-04-2011 06:39 PM
D2 Racing coilovers vs Ksport coilovers? spcgloc Wheels & Tires 18 09-24-2009 09:06 PM
