Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > General DIY Discussions > Detailing
Old 09-04-2013, 07:47 PM   #11
Vic Cardenas
Vic Cardenas's Avatar
What's the difference between this a "quick detailer" product? The cons I see with it is... No matter what, you're going to be rubbing contaminants into the wax underneath. There is no way 100% of what is on your car is going to end up in the rag. I wouldn't use this on a car with pristine paint.
AutoAlchemist.com
Old 09-04-2013, 08:45 PM   #12
greenswisher
greenswisher's Avatar
Real Name: Alex
greenswisher is on a distinguished road
It pretty much is a quick detailer spray, but it has more additives to lift dirt and for lubrication. I think you're supposed to only do one wipe per side of the towel to minimize the transfer of dirt to other parts of the surface.
greenswisher is offline   Reply With Quote
Old 09-05-2013, 03:48 AM   #13
My results using it Def saves Alot of time and effort great of u are no were here a hose
Old 09-05-2013, 10:49 AM   #14
smokinfastlegend
Gone.
smokinfastlegend's Avatar
smokinfastlegend will become famous soon enoughsmokinfastlegend will become famous soon enough
Send a message via AIM to smokinfastlegend
I dont understand why they call it waterless washes as its more so rinseless, not waterless.
I use either Optimum No Rinse or Quick&easy wash for these kinds of washes. Even with that, I like to make sure i at least have some mixed in a spray bottle so I can ensure the surface is wet. If done properly, you will not get any adverse effects in the paint surface. You just also have to realize when the car is too far off dirty to get a rinseless wash.
smokinfastlegend is offline   Reply With Quote
Old 09-07-2013, 08:49 AM   #15
Biggg72
The Big Bald 1
Biggg72's Avatar
Biggg72 is on a distinguished road
Send a message via MSN to Biggg72 Send a message via Yahoo to Biggg72
have any of you used fw1, its basically the same thing but in a spray can mostly used by nascar from the promotion? how does it compare?
Golfer Jerry Pate, an Alabama graduate and the 1976 US Open winner, said it best when he walked out of the Crimson Tide locker room after the game.
That, Pate said, was an ass-kicking.
Biggg72 is offline   Reply With Quote
Old 09-12-2013, 06:00 AM   #16
smokinfastlegend
Gone.
dont waste your money on fw1.
Old 09-12-2013, 06:55 PM   #17
speaking of these quick wax/washes... even after a couple trips through the car wash i didn't really see the pearl in my black GS until I hit it with some Showtime. Crazy.
Old 09-14-2013, 10:54 AM   #18
smokinfastlegend
Gone.
The reason why unfortunately is because car washes (tunnel or do it yourself with a brush) are highly not recommended for use if you enjoy your cars finish. Touchless car washes work, but do not remove all grime from your car. What ends up happening is that the brushes and tunnel system scratch the surface of your car terribly, dulling the finish and making your black car look gray as the scratches reflect all light that interacts with it. Touchless car washes only remove the loose removable layer of dirty from the surface and try to use harsh chemicals to remove anything else, but what ends up happening is you get a car that is still grimey.
To clean your car you need to interact with the surface, it just requires a certain amount of understanding to put the least amount of scratches into the surface while doing so.
Old 09-20-2013, 02:15 AM   #19
soloist
OCD Legend member
soloist's Avatar
Real Name: Brandon S.
Solution is easy, take a really epic photo of your car, store it on your smartphone. That way you can take a peak at it to remember that it can be that clean, then you only wash it when you absolutely have to, it's a theft deterrent as well as a finish preserving tactic. I HATE washing my cars, no matter how soft a towel, chamois or whatever I still end up seeing more little swirls and defects. I do realize that it is mainly psychological, in that I am likely cleaning the car to the point of seeing where the previous owner didn't take as much care, so I am essentially seeing all the imperfections made throughout the life of the car. But yeah, my solution is to wash my cars only a couple times a year, when they get hit with a dust storm, or snow/road debris gets up on the finish. I figure the layer of dirt that is on there probably prevents UV and more visible light from actually destroying the clear coat.
Old 09-20-2013, 08:28 AM   #20
more like the layer of dirt is further making it worse since any little thing will cause it to damage the paint.
Evans Waterless Coolant - Ever used it? Icewind 2nd Gen. Legend General Discussion 15 01-17-2013 08:33 PM
Waterless coolant?` LowPSI 2nd Gen. Legend General Discussion 21 05-30-2012 04:59 PM
DIY: How to wash a car GreekPower Detailing 24 07-03-2010 08:09 PM
FW1 WATERLESS WASH & WAX wonthuansoOp Detailing 27 06-21-2010 02:27 PM
At the car wash 94GS 2nd Gen. Legend General Discussion 32 09-04-2009 05:58 AM
