Old 11-01-2011, 02:21 PM   #41
oh geez..... all the BS has started again.
Hustlav6 do your self a favor listen to DV8,
My first response was, wtf.. a T1 Legend @ 7700 rpm the saw it was you and right away the BS light came on.
in my country dynamometers measure power on engine in other words "on crank shaft" ,
Incorrect if you would use any logic you see its reading out from your wheels,
True crank dyno's run of your flywheel directly those are the only ones that do direct crank hp.
A engine dyno......
Secondly could you PLEASE stop with "in my country" bs Poland isn't in a different galaxy.
yes my engine spins to about 7700 revs i can show you a vid of WOT hit with trans at N , with engine redlines at 7700 rpms
Dohh......
Mate bouncing of rev limiter doesn't mean your making any useful out put at that given level.
I highly doubt that even with your ported IM a C32A would make max power at that high a RPM. you'd need a serious intake and head setup to support that.
only possible remedy for this situation is replacing a trans for newer AT or MT,
Your having a laugh? i'm not even commenting this fail...
Old 11-01-2011, 04:50 PM   #42
Dv8
Life Ruiner
Dv8's Avatar
Originally Posted by hustlav6 View Post
there is a possibility that this dyno counts first power and tq on wheels and after it stops (this drop at 7200rpms)it finally sketches max torque and max power lines at engine (with power loss through whole rpm range added)
yes this is odd and different than US standards, but in my country dynamometers counts power on engine, probably as you said WHP + drivetrain loss = max hp at crank
if you use formula this formula (max torque x rpms of max torque)/ 7077 you will get (231 x 5250)/7077=171 KM(power unit) on wheels when you add value represented by lowest line which is max drivetrain loss of 85KM , 171+85=256 KM = 185 kW of max power it just make almost perfect sense
dyno operator told me the same when i asked wtf is that drop and huge spike after that, i was searching through their dyno data base and no automatic trans car was having even similar graph, so that is not something caused by dyno, operator or any equipment error
only possible remedy for this situation is replacing a trans for newer AT or MT, but that is not in my budget for now, because the car is going for sale
I wouldnt want to buy a Legend thats been revved near 8k that pours out blue smoke :\
~Dv8
GT-R 3/7/15 9.2 @151MPH | 12/19/13 994whp 895wtq Dynojet 186 1/2 Mile
16 yrs and counting. To many Experts, not enough Results. Where are yours? Retired Legend 616WHP@18PSI 10/11 12.1@124MPH 02/12 N/A 234whp 229lb-ft 13.7@99mph 95 deg. 06/07 Lexus IS-F Nitrous 11.3@123MPH 392WHP 372WTQ I/H/E N/A-Ladies car now.
Go-Kart 35whp 29wlbft http://www.2slik4u.com/
My Garage
"People can always copy what I did first" -Jesse James
RIP Dannie FUT James
Dv8 is offline   Reply With Quote
Old 11-01-2011, 07:42 PM   #43
Hustlav
Shut the fuck up.
Your dyno graph is bullshit.
Old 11-01-2011, 07:50 PM   #44
94_GS_Sedan
94_GS_Sedan's Avatar
Real Name: Sayed
94_GS_Sedan will become famous soon enough
Hustlav
Shut the fuck up.
Haha... I was waiting for you to chime in lmao!
-Sayed
94_GS_Sedan is offline   Reply With Quote
Old 11-02-2011, 05:47 AM   #45
hustlav6
hustlav6 is on a distinguished road
legend-coupe i gave a hard evidences of what i am talking about, so please if you do not have any constructive input in to the subject or maybe you can't read good - STFU dude
sr5guy - very constructive and very supportive post, do you suggest that i made that with crayons and scanner?
the video with rev up to 7500 rpms will come even today for all non believers
hustlav6 is offline   Reply With Quote
Old 11-02-2011, 06:08 AM   #46
as much as I don't want to jump in and support hustla... I remember someone posting he used to rev his c32 (can't recall if its a type 1 or 2) to almost 8k... hell it could have been hustla it was posted on the .com I believe.
Old 11-02-2011, 10:23 AM   #47
Dv8
Life Ruiner
Dv8's Avatar
If it was a linear line to 7700rpm and not a huge dip at 7200 then I would give the graph more credibility. Its also strange thats theres no 5250 intersect, but maybe thats an amercican dyno thing...
I dont doubt for a sec that anyone can rev to the 9k even, but why risk the engine for a few more ponies, if any at all?
... then he wonders why his lifters are ticking and puts in some strange weight oil...
Backwards.
~Dv8
My Garage
Old 11-02-2011, 10:45 AM   #48
hustlav6
Backwards.
~Dv8
don't wan't to litter in here more than some people did but in matter of fact i was unable to rev my engine further than 6500 rpms before putting telion type II ecu and type II cams, i'm revving the engine very occasionally to 5-6krpms
as for lifters i was witnessing this on whole oem setup, i was changing lot of oil types(now im driving on 10w40) and done miracles to get rid of that, vainly, than i stumble on vids of c32a engine revving and i thought they just sound like shit in comparison to c35a and i just accepted it , nothing to do with high revving engine
impossible, i was never able to log on .com
Old 11-02-2011, 03:13 PM   #49
hustlav6,
Dude.... revving doesn't equal power. and hell no this isn't a 4 cyl K,F,B,H screamer
This is called OVER-REVVING
your not making any power and just damaging the engine.
And could you please stop with this non-sens it's so annoying it's making lose my cool..... and is saying something...
Secondly the blue smoke is rather nasty this is your 3th engine already right?
Old 11-02-2011, 03:17 PM   #50
Maybe a very fortunate thing...:dunno:
OFFICIAL TATTOO THREAD T-Clyde The Water Cooler 190 03-17-2012 07:17 AM
4piston 2nd gen RL calipers on 1st gen RL OLD_HATCH 1st Gen. RL Performance Enhancements 16 11-06-2009 03:52 AM
WTB: 2nd Gen Legend Coupe Type II Legend64 Legend 8 07-03-2009 03:20 AM
Imbedded videos not working in 2nd gen forum whats77inaname Feedback and Requests 2 06-05-2009 09:24 AM
