Old 04-19-2010, 08:04 AM   #1
KJLegend
KJLegend is on a distinguished road
Default How long should a valve cover gasket job take?
I have leaking valve cover gasket on the passenger side. I was wondering how long it should take me and my friend who used to be a mechanic?
KJLegend is offline   Reply With Quote
Old 04-19-2010, 08:08 AM   #2
korrupt1
korrupt1 is on a distinguished road
ranks up there in the laziest question dept. Your 'mechanic' friend should already know this.
maybe 15-30 mins and that is if you are goofing off. Its a valve cover...not a head replacement
korrupt1 is offline   Reply With Quote
Old 04-19-2010, 08:10 AM   #3
lol would prob take me 2 days
Old 04-19-2010, 08:12 AM   #4
i'd say 15-30min is a stretch, but not too long. just make sure to use some hondabond to adhear the valve cover gasket to the valve cover to it doesn't get pinched or come loose as u install it. u don't need much just a little bit around the corners to help it stick in
Old 04-19-2010, 08:22 AM   #5
KJLegend
That was the answer I was looking for, thanks Alex!
My mechanic was not sure since he had never done one on a Legend, therefore I was trying to ask our wonderful forum members before jumping into it.
Now onto why its blowing smoke out of the tailpipe soo damn much while at idle... Valve seals? Piston rings? SHG for the 2nd time??
Old 04-19-2010, 08:35 AM   #6
korrupt1
is the smoke white? disappears after taking off? Sounds like BHG...thats what my G2 was doing....kept getting worse
Old 04-19-2010, 08:58 AM   #7
white smoke = coolant
Old 04-19-2010, 09:41 AM   #8
Vic Cardenas
Vic Cardenas's Avatar
Passenger side is easy enough for most novice mechanics to do. Just remove the coils and unplug the wire harness and move aside. There's not much else in the way.
AutoAlchemist.com
Old 04-19-2010, 10:26 AM   #9
antik
I blame the M3.
antik's Avatar
Get all the little grommets off and you won't have too much trouble.
Honestly, I struggled with it: I had no clue what I was doing and one of the sealing grommets was hella stubborn. Once it was off though, it was a piece of cake.
Be careful torquing on the far side: I snapped a stud (luckily up high so I can go in and replace it later pretty easily, with any luck) torquing the cover nut on. That thing only needs like 1 ft lb or something obscene like that.
'95 Auto L Sedan [SOLD]
Old 04-19-2010, 10:30 AM   #10
there 7ft lbs
Engine valve cover leak aseaz404 2nd Gen. Legend General Discussion 9 01-18-2010 09:23 PM
Side Cover Valve Gaskets? Jaysus! 1st Gen. Legend General Discussion 11 10-26-2009 06:56 PM
ebay valve cover gasket kit hotstartup 2nd Gen. Legend General Discussion 3 09-10-2009 08:07 PM
Valve Cover Gaskets Jaysus! 1st Gen. Legend General Discussion 10 08-25-2009 05:16 PM
Valve cover gasket set? Which ones? 91RosewoodBrown 2nd Gen. Legend General Discussion 9 07-08-2009 12:20 AM
