Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Second Generation Legend -- 1991 - 1995 > 2nd Gen. Legend Performance Enhancements
Old 06-05-2017, 07:35 PM   #1
jaconrad1
Real Name: Joseph
jaconrad1 is on a distinguished road
Default boring cylinder heads
I was wondering if anyone has had their cylinder heads bored out? If so what did you have them bored too? Pistons? ect... very curious if this has been done.
thanks
jaconrad1 is offline   Reply With Quote
Old 06-06-2017, 09:46 AM   #2
There's nothing to bore on the heads except the valve seats and if you are going to start messing with changing the valve size you need to do your research on calculating the right size based on changes you make to cams, intake, psi, exhaust and cylinder bore.
The information is readily available to a resourceful googler and it's all math. I'm not going to take the time to dig up my own research since doing the work yourself is very important to taking on a job like that.
Old 06-06-2017, 09:50 AM   #3
Send a message via AIM to GreekPower Send a message via MSN to GreekPower Send a message via Yahoo to GreekPower Send a message via Skype™ to GreekPower
yes its been done, but unless you plan on investing actual money into the motor don't bother.
I have custom valves, springs, ported heads, pistons, rods, etc all in a 3.5 just buy it and save yourself a ton of headaches
Old 07-26-2017, 10:01 PM   #4
Joe E
Formerly TypeRKon
Real Name: Joe Cyclone E
Joe E is on a distinguished road
Send a message via AIM to Joe E Send a message via Yahoo to Joe E
3.2 > 3.5
My block was bored and sleeved. I have forged pistons by CP and forged rods.
Way2Fast - Your Headlights Look Good In My Rearview
1994 - Acura Legend Coupe
2010 - Infiniti G37S
Joe E is offline   Reply With Quote
tl-s hub boring IamPlan_B Wheels & Tires 5 10-11-2015 03:09 PM
Widened T2 manifolds and the use of T2 cylinder heads on 3.5 soloist 2nd Gen. Legend Performance Enhancements 11 03-30-2012 12:16 AM
Removing cylinder heads. Need help bbjornson 2nd Gen. Legend General Discussion 12 02-28-2011 12:54 PM
Clutch master cylinder and slave cylinder Stillmatic OEM Parts 1 11-29-2010 03:51 PM
'89 rebuild cylinder heads for $200... pnoye2 1st Gen. Legend General Discussion 15 07-16-2009 09:18 PM
