Old 06-17-2019, 05:44 PM   #1
Method Maker
Youngest Enthusiast
Method Maker's Avatar
Method Maker is on a distinguished road
Default Time For A New Engine?
So after taking the dash apart to check solder points and manually testing oil pressure on my '87 Sedan, I believe the engine has no oil pressure. Oil light flickers and blinks whenever she's running, sometimes it turns off for a little bit but then comes back on. Engine isn't knocking yet so I'm gonna try replacing the sending unit and running a thicker oil, maybe 20w-40.
Anyway, if the engine is indeed on it's way out, would it be possible for me to swap in a 2.7l motor used in the coupes of the same generation? I'm guessing there are some differences, might just go with another 2.5l. Lots of stuff to be thinking about, still trying to decide what to do with her.
Lemme know what you guys think and if you have any ideas whatsoever!
Method Maker is offline   Reply With Quote
Old 06-23-2019, 04:24 PM   #2
AcuraG1Coupe
Real Name: Jay
AcuraG1Coupe is on a distinguished road
Should be doable. I have the motor from my coupe available.
http://forums.acuralegend.org/showthread.php?t=34923
AcuraG1Coupe is offline   Reply With Quote
Group Buy: Sr5guy Chipped Engine Computers, LAST TIME AT $75!!! SHIPS IN 3-5 days!!! sr5guy Group Buys 43 07-30-2012 01:39 PM
Pull Engine or Engine & Tranny?? Aking 2nd Gen. Legend General Discussion 20 03-20-2012 01:37 PM
What is the difference... Type II Engine & 3.5 RL Engine?? BRICKCITY 2nd Gen. Legend General Discussion 17 09-28-2011 08:48 AM
Engine Replacement... What to change while the engine is out? pacallen 1st Gen. Legend General Discussion 5 07-31-2010 08:52 PM
engine crank and won't start engine check light Legend95 2nd Gen. Legend General Discussion 0 12-22-2009 05:59 AM
