Old 04-16-2012, 08:18 AM   #1
holyabish1
holyabish1's Avatar
Default 91LS 5MT- Phase 3- Supercharged
Ok, I think it's time for everyone to know the reason for all the secrecy .
I'd hoped to wait a little longer, but I'm going to have A LOT of questions regarding how to accomplish this without screwing up my 3.5... qwqwqw! Also, the way I'm going about this, is to allow the same setup to be purchased by other members in the future. Meaning, the brackets, crank pulley, and parts should be able to get pretty easily (not cheap though..lol).
My first objective will be to clear a little more room in the engine bay. The wiring mess here will be tucked, along with the fan relay being moved just behind the headlight, or somewhere around there. I removed the windshield washing fluid reservoir, considering it didn't work anyway... heh. The coolant overflow is there now.
A few teaser shots of how everything will be going.
Thanks to Rob, Like_no_other, I have some spare piping to play around with, and a decent mustang "roto-molded" intake.
The extension tube on the vortech supercharger will be removed, so the pulley will be closer to the blower. So my rough alignment, I'm using the lip of the blower head unit, just along the edge of the alternator pulley.
For the crank pulley, you may have noticed, I put in for Telion's aluminum one. However, mine will be slightly different than everyone else's . It'll have an additional 6-rib section after the alternator section. No picture yet, but as soon as it is produced and installed, I'll post up!
Bracket
The bracket seems to be the hardest part thusfar, so I'm making a mock-up in 1/2 foam board. In the end, I should be able to use 1/2 steel or aircraft aluminum (whichever is more available for a good price). The bracket will be a three-piece...
1.) Rear main bracket will have several mounting points and be welded to the alternator bracket for support.
2.) Blower unit bracket. I wanted it separate so I could swap out head units later if I wanted to upgrade, and only change that part of the bracket out.
3.) Tensioner and Idler pulley bracket. Will sit on top of the main bracket.
This is just the main bracket I started this weekend, please excuse the roughness. All details will be worked out soon.
I will be deleting the top lip that goes to the top timing cover bolt hole. A curved bracket will take it's place. The Outlet of the s/c was rubbing against it, preventing it from going on correctly. I'm also going to delete the lower most bolt that goes into the motor mount bracket. If I used that bolt, I wouldn't have air conditioning . I've made up for the lost bolt though, by deciding to weld directly to the alternator bracket. i can also clear a little more room around the alternator tensioner so I can actually take off the alternator belt..heh.
First attempt:
Second attempt: Still rough cut.
Here's a pic of the first day I got the package from Rob.. just messing around, but you can see the intake in this one, so I'll post up.
Well, there you have it, where I'm going with all this craziness. Deadline is July 26th .
The body will more than likely still look like shit, but this will make up for it!
Original drawing of how the 3 brackets will work. Of course, it's completely different now..lol, but you'll have a better idea.
Old 04-16-2012, 08:34 AM   #2
Looks good
Old 04-16-2012, 08:38 AM   #3
Canadian144
Canadian144's Avatar
Real Name: Ryan
Canadian144 will become famous soon enough
Sexy! Keep us updated.
92 Legend coupe / 92 Integra GS-R / 09 STI
Canadian144 is offline   Reply With Quote
Old 04-16-2012, 09:01 AM   #4
iiinnntteresting.....
Old 04-16-2012, 09:18 AM   #5
like no other
Getting It Done
like no other's Avatar
like no other will become famous soon enough
Good idea making the mount out of foam first. I wish I thought of that If you have any question I can help you with let me know. Good job so far
hard work + dedication = perseverance
like no other is offline   Reply With Quote
Old 04-16-2012, 09:30 AM   #6
holyabish1
holyabish1's Avatar
It was cheap at Lowe's too! 11 Bucks for a 8'x4' sheet! I wasn't a fan of the expanded polystyrene boards, but i like the durability and even-ness of Shiplap Insulation.
Oh, forgot to mention, I re-installed the 3.5 mid-mount on the driver's side. A bracket (odd shape) will go from the lip (that goes between the body and alternator) back to the mid-mount. 3.2 motors do not have this mid-mount.
Old 04-16-2012, 01:23 PM   #7
So there is a lab up in Kentucky also I see! Good work there Abe. I'm still keeping a few FrankenGStein notes from the lair in my Mad Scientist mind and soon to be tried out in the lab! I can't recall for sure where the Korean members mounted their supercharger but I'm thinking they removed the air box and mounted their brackets and blower on that side of the engine bay. Either way S/C plus A/C = WIN!
Old 04-16-2012, 01:31 PM   #8
<-- blinks
That is an awesome idea for some sort of support, will be tight but doable.
You came up with that all by yourself?
Old 04-16-2012, 01:43 PM   #9
holyabish1
holyabish1's Avatar
<-- blinks
I think so... lol. I've had so many conversations on IRC, I'm not sure what's my idea and what's other people's idea..lol.
Old 04-16-2012, 01:50 PM   #10
L3GDKANG/JDMKANG
JDMKING Legend GOD
L3GDKANG/JDMKANG's Avatar
L3GDKANG/JDMKANG is on a distinguished road
im tuned in on this 1!
Fut rip! Knowledge, Wisdom, Understanding = 360 L.A.麺部
L3GDKANG/JDMKANG is offline   Reply With Quote
91LS 5mt- Commencing Phase 2 of 4 for the build!! holyabish1 Legend Builds 63 05-31-2017 05:13 AM
Happy b-day to 91LS 3.5 (corrie) bsmooth1027 The Water Cooler 24 06-20-2011 10:53 AM
Supercharged Legend? Poochmike "Not Mine" 7 07-25-2010 08:04 PM
