Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Marketplace > Group Buys
Old 01-17-2018, 02:32 PM   #291
holyabish1
holyabish1's Avatar
holyabish1 will become famous soon enoughholyabish1 will become famous soon enough
I didn't have to shim mine at all. The pinion bearing still mated up almost dead center to the ring gear after install. I also had the right amount of backlash.
Sent from my iPhone using Tapatalk
holyabish1 is offline
Old 01-17-2018, 02:39 PM   #292
holyabish1
holyabish1's Avatar
Only tools you will need once the diff is out:
Nylon deadblow hammer
Oven or bearing warmer
Socket (12mm I think and 10)
Bearing puller or three legged pulley puller
Brake clean
The differential innards come out as one piece and you're pretty much swapping over the ring gear and VSS gear. New or reuse your differential carrier bearings.
The pinion should sit just about where you need it to already. Only adjustments I can see are the side thrust washers to move the ring gear closer or further away from the differential.
Old 01-17-2018, 03:42 PM   #293
holyabish1
holyabish1's Avatar
Some extra pics to go along with the DIY thread linked above.
Pulling VSS gear
Same puller was too fat at the feet to get under the bearing.
I bought this from Autozone fit better
Orion Modified his:
To put the bearings and VSS on I had the oven at 250*, let them sit for about 10 mins. Their temp was about 180* when I slid them on. Slight tap with nylon mallet and it was good. Listen for sound change so you know it's bottomed out.
Whole unit goes back in as one piece. Honda Bond and reinstall cover like the PG DIY. No fooling with the diff pin or any of that part of the PG DIY.
Old 01-18-2018, 05:19 PM   #294
brokeviolinist
brokeviolinist's Avatar
Real Name: Aaron H.
brokeviolinist is on a distinguished road
Talking
This is amazing, fantastic, super helpful information--thank you so much!!!
"Camille," Rebuilt TII 5MT swap, MFactory LSD and total front end rebuild underway, P/P heads & manifold, ram intake/Remus exhaust, OBX headers/Y/cat delete, Telion chip, ~2" drop, Koni Reds, 17" wheels, poly bushings, solid mounts, Addco rear sway bar, drilled/slotted rotors, wood trim, PPG base/clear urethane paint, Escort Passport 9500ci, owned since '04, G2 Legends in family since '91
brokeviolinist is offline
Old 01-19-2018, 08:39 AM   #295
holyabish1
holyabish1's Avatar
Default MFactory LSD Group Buy
Not a problem. I have some vids around too.
The biggest reason I can see for the need for thrust washers are the variations in casting of the differential housing. When measuring side by side the differentials themselves were identical. Therefore the need for changing thrust washers should be minimal. Since you're using the same housing. Every differential should be closer to spec compared to the cast housing.
Old 01-20-2018, 05:05 PM   #296
brokeviolinist
Real Name: Aaron H.
+1
Got the new LSD carrier installed in the housing this afternoon! (It's a cast iron MT diff btw.)
Swapped the (perfectly good) used bearings onto the new carrier: before and after backlash and preload were identical, like I didn't change a thing. Prussian blue on the gears showed perfect mesh. No change to any shims necessary at all.
I love it when a project is easier than anticipated!!! A few more weeks (or maybe a month or two, idk) till the front end is rebuilt and I get to road test it!
The MFactory unit is absolutely gorgeous, the very highest quality. It's just beautiful, as close to perfect as it could be in every way. Amazing. Kudos to MFactory--and all you guys that stuck with this crazy GB through thick and thin! Worth the wait, I dare say. Thanks be to God!
Old 01-20-2018, 07:23 PM   #297
holyabish1
holyabish1's Avatar
Awesome. Thanks for the follow up. Any pics ya got to share?
Old 01-30-2018, 09:31 AM   #298
brokeviolinist
Real Name: Aaron H.
No pix, sorry! Yours are great, it all looked the same, went together perfectly. I'll update when the car is back on the road... Thinking I could really use a tougher clutch while I'm this deep in...
Old 03-26-2018, 12:51 PM   #299
lgnd4u2nv
lgnd4u2nv's Avatar
Real Name: Richard
lgnd4u2nv is on a distinguished road
reading through this thread.....wow....seems like getting this part made, paid for, and shipped was rough. But I'm glad that people within this community were able to get things back on track.
I'm just going to throw this question out there: Was anyone part of this group buy that has since changed their mind or maybe had something come up, and no longer wants their LSD? If so, shoot me a PM.
Sedan Sold in 2009. Coupe coming soon??
lgnd4u2nv is offline
Old 04-04-2018, 02:00 AM   #300
Karo
Karo is on a distinguished road
Had to read thru a lotta bull but have a read correctly that I’m not able to get an lsd or my money back even though you were refunded for faulty units
Karo is offline
lsd, mfactory, quaife lsd
FELLER: MFactory G2, RL, TL Auto/Manual Quaife LSD The-Teej Group Buys 62 12-01-2015 02:34 PM
can another group buy be done for the ksports!!! 93-ka7 Group Buys 5 07-17-2011 05:22 AM
possible group buy, something to think about daveCFPrez 2nd Gen. Legend General Discussion 3 04-07-2011 02:45 PM
mod express hid group buy Ian Group Buys 27 03-08-2011 03:51 PM
Group Hug! GreekPower The Water Cooler 27 11-10-2009 12:59 PM
