Old 08-31-2020, 12:45 AM   #1
Gothche
Gothche is on a distinguished road
Default vss or something else
After having my shg replaced, I have been driving my car as normal, but I noticed that the speed shown at the speedometer has changed all of the sudden.
Before it was very precise and showed the same small difference in shown speedometer speed and actual speed, no matter how fast I drove, but now the difference is a lot more and it increases with speed.
I don't have an erractic speedo needle or anything like that, and is still on the stock wheels and stock dimension tires.
When driving at shown speed of 31 mph there is a difference of about 7 mph to actual speed (38 mph), and that difference increases as speed rises. So at 68 mph (shown speed) the actual speed is 78mph, at 80mph (shown speed) actual speed is 92mph..
So is this a typical vss failure symptom or could there be another problem.
The reason why I ask, is because I had another Legend owner tell me that his similar problem didn't get fixed with replacing the vss with a new one.
Hope anyone has some insight.
Gothche is offline   Reply With Quote
Old 08-31-2020, 01:27 PM   #2
Normally not a VSS issue.
Old 08-31-2020, 01:35 PM   #3
Gothche
Do you have any ideas about what else could cause this?
Old 09-05-2020, 09:58 AM   #4
LegendWiki - G2: Service Manuals And TSBs: 91-048 - Speedometer Reads Too High
EDIT: As mentioned in the TSB, this isn't actually a calibration, all it does is lower the gauge reading. How are you comparing the speedometer to you supposed actual speed?
Old 09-06-2020, 08:57 AM   #5
91RosewoodBrown
Legend Enthusiast
91RosewoodBrown's Avatar
Real Name: Ben
91RosewoodBrown will become famous soon enough
Didn’t change your tire/rim setup recently? VSS I believe counts revolutions, so changing your rim/tire size could throw off your speedo like you’re describing. Otherwise, this doesn’t sound like a typical VSS issue.
91RosewoodBrown is offline   Reply With Quote
Old 09-06-2020, 10:51 AM   #6
Gothche
Wheels and tires are stock dimension
