Old 02-12-2018, 09:39 AM   #1
IamPlan_B
Default Legend still has over heat issues
VWhen driving , coolant temp is ok until i hit some traffic that makes me slow to almost stop , and continue in stop n go heavy traffic, when the needle starts to go up to 3/4 the way up but will drop after i accelerate, then start to go back up even highér and pretty much stay there. Doesnt go all the way up , but almost.
I have bled the air out countless times, because air in is usually the culprit. I have the throttle body bypassed as well as heating system (bad heater core) in back of motor. Replaced switch that sends signal to gauge and new oem tstat. After engine shutoff the fan motors kick on but they seem like they weak or slow, i dunno.
Have a spare set of fan contol and fan timer (passenger side next to ecu and on right kick panel) and fan relays that im gonna switch to see if anything changes.
Am i missing something or have over looked something?
When i open up the bleed nipple first , i can hear a little air escaping, then remove rad cap, then squeeze upper hose to get air out, then add coolant until it shoots out of nipple then close it to prevent air going in there, start car to see if level drops then reinstall cap. Drive around block then remove cap and check level. Thats what i do like 1-2 a week
https://www.dropshots.com/Implan_b/d...2-12/13:19:31#
Old 02-12-2018, 11:24 AM   #2
IamPlan_B
https://www.dropshots.com/Implan_b/d...02-12/13:19:31
Old 02-12-2018, 02:18 PM   #3
If repeated attempts at bleeding the coolant never seem to get out all of the air, you have a leak (could be internal or external). But first, using a spill-proof funnel (Lisle LIS24680 is the common one around here) is the only method that works to get out 100% of air, so do that first. If you still end up with air in the system, you'll need to do a pressure test to locate any external leaks, and then a leakdown test to check for internal leaks.
Old 02-12-2018, 04:06 PM   #4
IamPlan_B
Where would i find this funnel?
I did head gaskets a few months ago , due to shg on #6 cylinder, theres no sign of internal or external leaks
Old 02-13-2018, 09:21 AM   #5
ari_one
MeltingInTheSun
ari_one's Avatar
You can find the lisle funnel all over the place including amazon (about $30). Do a search and it will pop-up all over the place.
Old 10-26-2019, 02:30 PM   #6
IamPlan_B
I know this is my old post, but still have same issue. I bought a lisle funnel, and drain all the old coolant out and refill with new coolant, once full , I install the lisle funnel and fill 1/3 with coolant, run it for a while, saw a lot of air bubbles come out and had it running for a while, fans coming off and on until I felt I had out all the air.
I'm still getting temp needle going up and now its getting up higher and taking longer to drop after I accelerate. I tried burping/bleeding this system numerous times.
the heater valve and core have been bypassed because of bad core, throttle body bypassed, and replaced all hoses that I can get from dealership , so now leaking hoses. replaced head gaskets less than a year ago.
what am I missing or over looking
Old 10-26-2019, 05:56 PM   #7
Time for a pressure test
Old 10-27-2019, 02:36 AM   #8
4HondaOwner
Premium Gas Only
4HondaOwner's Avatar
Real Name: Kevin A
How old is your radiator?
1-1-2021 * 94 LS Coupe 6 Speed 336,126 miles * December 2020 miles driven = 406
Old 10-27-2019, 11:59 AM   #9
IamPlan_B
radiator is new, purchased in march.
now temp goes up fast and stays up the whole time I drive. went on a 40 mile drive last night (20 ea. way) and temp never went under half , stayed at 3/4 the whole drive. I burped/bled the system before I left. so does that mean I have more air in system as before?
pressure test? are you referring to a radiator pressure test, because I've never done or tried to one before on this car and I have a pressure test here
Old 10-27-2019, 12:10 PM   #10
IamPlan_B
reservoir bottle does not fill up as before when it suffered a SHG , and I don't smell or see any coolant in dipstick, and I don't smell it when driving. I'm not losing coolant, and no visible traces of leaks anywhere.
I've owned and worked on this car since 2000 and know my way around this car. she has 238,000 and suffered a BHG in '08 and SHG in '17 .
FS: ACURA LEGEND BLOWER MOTOR SPEED TRANSISTOR RESISTOR HEAT 077800-0172 jose3030 OEM Parts 1 02-27-2016 01:35 PM
93 legend L radio issues lcole 2nd Gen. Legend General Discussion 12 01-29-2014 11:32 AM
Lack of heat issue on 3.5 Legend Sedan metpage 2nd Gen. Legend General Discussion 3 01-11-2011 08:46 AM
1988 Legend L AC issues wesmagyar 1st Gen. Legend General Discussion 7 09-12-2010 10:24 PM
heat heat an heat issue help 90ls 1st Gen. Legend General Discussion 24 01-28-2010 08:22 AM
