Old 05-19-2020, 07:55 AM   #1
Drewdog
Drewdog is on a distinguished road
Default 95 won't stay running g
hello all,need some help figuring out why my 95 type ll won't stay running starts fine then immediately dies,like its out of gas,which its getting,changed fuel filter,same thing,is it not getting enough pressure,main relay? Any advice would be great thanks drew
Drewdog is offline   Reply With Quote
Old 05-19-2020, 07:31 PM   #2
Hi Drew,
Welcome to the forum.
Does it go dead when you let off the starter?
Old 05-19-2020, 10:05 PM   #3
94LegendaryAcuraGS has a spectacular aura about94LegendaryAcuraGS has a spectacular aura about
Sounds like the idle control valve needs adjusting.
Old 06-17-2020, 03:07 PM   #4
stephen
stephen is on a distinguished road
That is a symptom of a bad main relay.
stephen is offline   Reply With Quote
Old 06-26-2020, 03:53 PM   #5
Drewdog
Default 95 legend won't stay running
hello thanks to those who responded,but I couldn't figure out how to get back on this forum,using my phone,the car stays running when I hold the key forward,1 or 2 seconds,
Old 06-27-2020, 06:26 PM   #6
stephen
OK. So that could be a bad ignition switch.
Old 07-02-2020, 04:21 AM   #7
Definitely sounds like a bad ignition switch if you are having to hold the key forward. The contact position is no longer being properly maintained. As you're probably beginning to learn these cars can be be a bit tricky to troubleshoot.
The main relay as suggested by stephen usually has an additional symptom which your original post didn't mention. Normally those have issues on relatively HOT days OR you had been driving for a while and the circuitry in the relay has heated up. The short version is the solder joints to the boards crack and the heat expands the joints so they don't make good contact. When they cool down they contract and make good connection again. Usually on initial startup for the day main relays work (since they're relatively cold). The relay literally stays on the entire time the ignition is on as its ONE function is to continue to tell the fuel pump "hey pump keep pumping until I no longer am on. When they fail the fuel pump sits there doing absolutely nothing so the car normally won't start although on rare occasion I have seen there was just enough fuel to ignite and turn the engine over then it dies. It NEVER hurts to have spare working main relays nearby.
Keep us informed.
LED stay on 95pearlwhiteGS 2nd Gen. Legend General Discussion 5 10-05-2012 12:27 PM
STAY AWAY from the NW daveCFPrez The Water Cooler 13 05-23-2011 05:43 PM
Who here stay out San Antonio? B+O The Water Cooler 3 02-14-2011 06:03 AM
Would you let him stay or not? whats77inaname The Water Cooler 37 08-27-2010 06:15 AM
Stay-Cations anyone... pnoye2 The Water Cooler 27 06-11-2009 11:42 PM
