List of tools I used.
Hammer Plyers 1/2 & 3/8 ratchet 10, 16, 17, 22, and 25 (or 24mm socket sorry cant remember) Ball joint Press Ever Tough Honda Ball Joint Set Fork Ball Joint Seperator Jack and 1 Jack Stand ![]() ![]() ![]() Step 1: Jack up vehicle and remove tire. Make sure you leave car on Jack stand so that we could use jack to do our next step. Step2: Put jack under bottom ball joint to straighten up our upper ball joint. This will make it easier to take out upper ball joint. ![]() ![]() ![]() Step 3: Grab your Fork Ball Joint Seperator and put it between the steering knuckle and ball joint. Now hammer away until loose. ![]() ![]() ![]() ![]() Step 4: Prepare ball joint press and honda press kit like so (btw make sure the ball joint press you use is not bent as you can see like the one i rented. It still worked it was just hard to keep straight) ![]() ![]() ![]() Step 5: Now get ready to press out ball joint like so. ![]() ![]() ![]() Step 6: Get your 22 mm socket and 1/2in ratchet to tighten ball joint press and squeeze out ball joint from upper control arm. ![]() ![]() After a few good turns TADA!! Ball joint is out. ![]() Now to install the new SPC Products ball joint. Once you buy the ball joint it should have instructions so I'm just gonna post pictures in order of what I did. BTW on this picture this plate is the only one you will have to press into the control arm. ![]() ![]() ![]() ![]() ![]() Put bottom bolt back on and put pin through hole. thats it your done and now go get you lifetime warranty alignment at firestone and you should be good. OH one last thing......When you go to get it aligned DONT FORGET TO TELL THEM YOU HAVE ADJUSTABLE BALL JOINTS so that they can properly get your chamber fixed. Well I hope I didnt leave anything out if I did plz let me know. Thanks for looking. ![]()
OH MY lord you are my savior. When my parts come in next week i have to install my upper ball joints and i couldnt find a diy other than the manual and it is not as detailed as you instructions. I cant wait to install it and see how it feels. I also have the unlimited alignment from firestone which i used 8 times so far lol FTW!
edit... after looking at the pic on my computer i never knew you could seperate the ball joint from the control arm. i was told by acura and few other people that the upper ball joint was built into the upper control arm and that it was a one peice unit. Damn i already ordered the part which was 200... oh well ![]()
#3 | |
![]() Quote:
![]() You know I think I heard that some where also (ball joint and upper control arm being one unit), but I knew that couldnt be right. Sucks you ordered the part but hey a new part would be nice too. I hope I explained myself so that even a cave man could install an upper ball joint. Oh if you can get someone to at least hold the ball joint press it would be a little easier so that the fittings dont move.
Seattleite
Told ya it'd be easy.. I was quite surprised.
1994 Acura Legend LS 3.5 - 284k SOLD. [02/21/2013] RIP Fut.. Never forgotten. ![]() |
#5 |
Yea the first one took me like 3 hrs, but thats probably cause i was stopping to take pictures and hoping that i would miss a set for this DIY lol
Official Photog
I just installed these and had the car alligned with my koni drop my wheels were at -1.5 deg now i have them set at -.5 deg and i have a slight rubbing issue at the top of the fender liner. Other than that i love them
#7 |
looks good, I had mine installed for 40 bucks with a alignment so I can't complain haha.
I love the adjustable ones ![]()
PM BOX IS FULL! Text me 724-584-0340 7/28/10 7:37pm Hell has frozen over Greek REMOVED his engine 1/26/13 7:23pm SHE RUNS! ![]() 5/18/13 3:27pm DYNO! 577whp/501wtq @19psi |
#8 |
Start to finish it only takes like 30-40 min tops
#9 | |
Go, Green Ranger GO!
Real Name: Me
![]() Quote:
And great write-up! ![]()
[SR5guy Stage III ECU | Cold Air Intake | Remus Exhaust | Fut
![]() [6000k TSX projector retrofit | 6000k Hella Micro DE foglights] Last edited by Riboflavin; 11-08-2009 at 09:53 PM. |
#10 |
Seattleite
What are you waiting for?! Autozone rents you the ball joint press and necessary adapters for free and it'll only take you an hour or two to get this done start to finish. It really is that easy! Then firestone for lifetime alignment!
DIY: Rear Upper Ball joint/control Arm [replacement/testing] Camber kit bonus | Alperovich | Second Generation Legend (1991 - 1995) | 11 | 01-16-2015 11:08 AM |
Wheel bearing or Ball joint? | Dethred | 2nd Gen. Legend General Discussion | 20 | 11-24-2009 06:54 AM |
FS: SPC Ball Joint Camber Kit -1.5 to +1.5 | arrozburner | Non-OEM Parts | 5 | 11-04-2009 12:03 AM |
Has anyone installed upper ball joint? | spcgloc | Wheels & Tires | 6 | 11-02-2009 08:25 AM |
New ball joint boots | Roger | 2nd Gen. Legend General Discussion | 13 | 07-01-2009 07:57 AM |
