Old 04-09-2010, 12:39 PM   #41
DSL
'93 3.5 type 2 coupe
DSL is on a distinguished road
cool... im going to poly fill these, cut it down/chamfer it, then press it in.. hopefully in the next 2 weeks..
'01 3.5l rl engine- 6 speed, type2- cams, valve springs/retainers, and intake manifold.
ground control, koni, addco-front & rear, 18" volk III
rm racing intake, gasket match ported exhaust manifold
DSL is offline   Reply With Quote
Old 04-09-2010, 12:51 PM   #42
^ u got more pics of the new bushings?? i'm probably gonna order a set as well on monday. i just pulled the mount bracket thing off my parts car, its actually in good shape unlike on my coupe its cracking.
u can actually see right away when u look at the car sitting there, and i noticed this earlier, the pass side control arm assembly hangs down more then the driverside, i checked em out and the pass side is def all cracked.
i too am wondering if filling a decent mount will help it stay stiffer and last longer. maybe this will work too
Old 04-10-2010, 09:57 AM   #43
DSL
filling the little gaps will make it stiffer laterally, which should stabilize the lower control arm and controlling the toe in/out under acceleration/braking, thus making the handling more precise.
We'll see what happens. Also, I bought aftermarket ones, but after lookin at phystein's pix i think you will have better results with the original ones from the hyundai dealer.
Old 04-29-2010, 12:35 PM   #44
DSL
is that a radius for a chamfer???
if its a radius? what is that radius?
if its a chamfer, what the angle?
thanks for your answers
Old 05-04-2010, 01:27 PM   #45
lgnd
EDM KA8 owner
lgnd's Avatar
Real Name: Istvan
lgnd is on a distinguished road
60 degree at my best knowledge. Reuse the oem part that's the easiest way.
lgnd is offline   Reply With Quote
Old 05-05-2010, 09:14 AM   #46
DSL
really?? it looks like a radius in that picture...
as for the original part, i am not using it. i bought bushings for the sonata which i will be modifying to make fit. i want to make sure i have the right tools before i take my bushings apart. my car is a daily driver. i need to finish this in 5 hours, so i need all the info possible. thanks
Old 05-09-2010, 05:00 PM   #47
i didn't get a chance to throw in some sonata bushings but i had one that was broken, so i decided to try the poly in the meantime.
i know its sloppy but i got distracted and spilled some, lol
Old 07-26-2011, 07:53 PM   #48
OLDSKOOLACURA
legend love
OLDSKOOLACURA's Avatar
did you ever try it out?
why does shit have to be so damn hard, wish we could just buy the damn bushings
Old 07-26-2011, 08:09 PM   #49
jeff i have it done on my car... so far its holding up lol
Old 07-26-2011, 08:35 PM   #50
OLDSKOOLACURA
legend love
how is the ride? granted you have stiffer suspension.
I'm doing air suspension so I'm not too worried about having a hard ride, but reading what Matt said about the suspension having to move made me do a face palm because I was so eager to get these done I didn't even think about it.
then again if you use a softer poly it might be closer to OEM, it still won't be the same but it should be better. Then we can do the Sonota bushing for a few spots but the other bushings I don't see how it could work, they stick out each end so it's not like we can just poor it in..............*^(&*%$*^&^!!!!!!!
Driver side upper Control arm Roger OEM Parts 3 10-24-2009 01:13 PM
Front Upper Arm torque specs Roger 2nd Gen. Legend General Discussion 0 07-19-2009 07:47 AM
Right upper A control arm Roger OEM Parts 0 07-12-2009 09:17 AM
New rear control arm creeking Roger 2nd Gen. Legend General Discussion 0 06-29-2009 06:27 PM
Rear control arm custom bushings lgnd 2nd Gen. Legend Performance Enhancements 8 06-19-2009 11:52 AM
