Old 07-08-2010, 08:25 PM   #11
Ablest31
Ablest31's Avatar
Ablest31 is on a distinguished road
Yeah, I did the ground the front harness to the chassis. Is that binging sound normal? I wouldn't think so cause it doesn't do it when I plug back in the original 14 pin that was in there. I am going to back track and make sure everything is as it should be. Fog button still doesn't come on. Do you have a picture of where you ground the harness in the chassis? Also, what about that blue connector with the red wires. Mine get hot is that normal?
Ablest31 is offline   Reply With Quote
Old 07-09-2010, 05:21 AM   #12
MXHalofan
Type O Master
MXHalofan's Avatar
Double check ground first. There's a factory bung for the ground using a 8x1.5 bolt (usual 10mm). I'd check continuity to ground from the plugs at the fog light connectors. Then check and see if you have voltage at the fogs.
91 Coupe LS black on black
GS wheels
MXHalofan is offline   Reply With Quote
Old 07-09-2010, 05:06 PM   #13
Ablest31
Ablest31's Avatar
I finally got them on. I had to do back and make sure all of my connections were on all the way and that is what did the trick. Thanks Mxhalofan
Old 07-18-2010, 02:50 PM   #14
kotetu
Never compromise.
kotetu's Avatar
kotetu will become famous soon enoughkotetu will become famous soon enough
dang we have the same problem in Lady6spd's GS. Gonna look for grounding problems...
Checks and balances no longer work. We need a return to fundamentals. We need to trim the fat and get back to a true Constitutional Republic, and that's why I'm with Rorschach. Never compromise. Not even in the face of Armageddon.
kotetu is offline   Reply With Quote
Old 03-03-2011, 05:06 AM   #15
MarcD
Low mileage nutso
MarcD's Avatar
Thanks for this write-up. That one connector for the wire running to the front bumper (red/black wire) was a real PIA to find! Your picture helped me on the location though
Old 03-06-2011, 07:53 AM   #16
MarcD
Low mileage nutso
MarcD's Avatar
One other tip- read this bulletin first:
http://www.acuralegendwiki.org/image...ws_1994-07.pdf
I used a blue connector since I could not find a 14pin gray one. Turns out when wired to the blue connector, the fogs will only work with the car not running. On the coupes, your connector might be green like mine was
Old 10-22-2011, 01:51 PM   #17
jmsmiff
jmsmiff's Avatar
Real Name: Ray
jmsmiff is on a distinguished road
I been at this all day. I'm not getting power at the fogs! What's wrong
jmsmiff is offline   Reply With Quote
Old 10-22-2011, 04:56 PM   #18
Did u tap the correct wire ?? The one behind the dead pedal taped to the harness
Old 10-22-2011, 05:36 PM   #19
jmsmiff
jmsmiff's Avatar
Real Name: Ray
You mean the brown one? He's got the right ones tapped except on the fuse box he's using the #2 fuse next to the op. he labeled it himself. I'm confused about the head lamp connector; mine looks different, and it different say where to plug it
Old 10-22-2011, 07:18 PM   #20
One6DSwifflY
Brooklyn Memba
One6DSwifflY's Avatar
Real Name: O...
One6DSwifflY is on a distinguished road
Smile U need this
http://forums.acuralegend.org/access...eets-t242.html
Instructions GL
"This 1 is for BROOKLYN! Land of da Crooks, home of my dame..." do ya research!!
One6DSwifflY is offline   Reply With Quote
oem fogs or these vinh291 2nd Gen. Legend General Discussion 22 10-21-2009 08:20 PM
OEM Fogs samo8ty5 1st Gen. Legend General Discussion 21 10-12-2009 06:48 PM
OEM Foglight Questions / Install Problem FutureX 2001 2nd Gen. Legend General Discussion 20 08-18-2009 08:10 PM
