Does anyone else have one? My legend had it when I got it and my roommate says it will mess up my main bearings
The only thing I'm worried about for the sake of my main bearings is the presence of oil.
![]() If your roomate has some hard proof, and I'm talking on the C32A or C35A engine, then that would be helpful. If our lower end was that fragile then every one of us that put an MT flywheel on a 3.5 would be in big trouble. I understand the merits of balancing both ends of the crank, but I think Honda made bullet proof mains because not even they balanced everything to perfection. Same two piece C32A pulley was fit to the A/T, Solid and Dual mass flywheels. I think your 3.5 is fine with a lighter pulley, but if you get uneasy about it there are plenty that would send you a stock pulley for a straight up trade. rich
Real Name: John
What he said!
Sent from my iPad using Tapatalk HD
Super Duper Member
tell your roomate he's wrong. Tell him we're dealing with a balanced bottom end that doesn't need external balancing like a small block Chevy engine.
RIP Fut. ![]() 3.5 swaps, head gasket replacements, and 5/6 speed swaps done in less than a week. PM for a quote. |
#5 |
Real Name: Mark
Is the 3.5 still internally balanced? I know the 3.2 is...... Either way 3.5 is smoother and has balance shaft
Sent from my iPhone using Tapatalk while pooping
FS: 3.5 Aluminum Crank Pulley | 94LegendaryAcuraGS | Non-OEM Parts | 35 | 05-24-2013 01:44 PM |
FS: 3.5 Aluminum Crank Pulley | Ablest31 | Non-OEM Parts | 11 | 03-26-2013 08:57 PM |
FS: C27 Aluminum Crank Pulley | "Chopped" | Non-OEM Parts | 6 | 03-15-2013 02:02 PM |
aluminum crank pulley | 95pearlwhiteGS | OEM Parts | 3 | 11-27-2012 06:31 AM |
91-92 Crank Pulley- will take aluminum too. | holyabish1 | OEM Parts | 1 | 12-18-2010 06:53 PM |
