#11 | |
![]() Quote:
I recommend doing practice at a local yard that has a Legend, if the moldings get messed up then no loss for you. Just try to be as careful there as you would on your own car... the person behind you may be blessed by the fact you left some nice moldings behind for them. rich
#12 |
Excellent write up! Got a bad leak in the trunk of my coupe most likely due to this.
#13 | ||
Love that ride!
Real Name: Eric
![]() Quote:
Being here in the NYC metro area - there's not really the kind of junkyard business found elsewhere where you can just walk in and "pick and pull"... unless someone knows something I don't know about this region and can advise me otherwise. Also, I thought I was a wise guy and seam sealed the moldings with RTV where the old visible black rubber gaskets were not in such good condition, thinking that would also help to waterproof it. And yes, I've cleaned out the moon-roof drains and have the new tail-light gaskets just delivered and at the ready (yes, Ken/CT Legend - that means I'll be changing the driver side tail-light housing soon, and MarcD - I'm opting not to use silicone caulking fix thinking I don't want to hassle with everything sticking together in case I need to take it apart....)
'93 Legend Sedan - Original Owner "Me" and "Mini Me" Last edited by Legend to Grave; 08-15-2013 at 03:17 PM. |
#14 |
Looks like a soft foam seal / tape that is 1/8" (3mm) will do the trick. I'm looking for something softer than the foam on amazon/ebay (sponge neoprene). I've pretty much decided that the stuff with an adhesive backing is not the way to go if you are cutting the gaskets yourself... what a pain.
I'll let you know if I find something I like. rich
#15 |
I think I've decided that I'm okay with the Armaflex Insulation tape even though it has an adhesive backing. It's 1/8" thick and has a pretty nice density. The stuff I have is a roll that is 2" wide.
I cut a few by hand and thought to myself how much better it would be to be able to stamp them out with a die cut. Then I remembered I had some used axle bands in the garage that probably would make good die cut blades... so I made a special tool! ![]() I used Gorilla Glue to fill in and adhere the stainless bands to the wooden block which I had used a dremel tool to carve out the blade seats. I was liberal with the Gorilla Glue and that became a problem since the goop grew like 3 or 4 times while curing!! next tool (this is a prototype) I will put the Gorilla Glue in the groove and then install the blades. After 4 hours or so I decided things should be good enough to go, so I pressed my first set only to be reminded that I needed to sharpen the blades... the bands were way too dull without having an edge filed (or dremel tool sharpened). I also found out that sharpening the bands into blades should be done BEFORE bending and cutting because doing it after the fact is a royal pain!!! Once I felt I was "pretty sharp" I cut a piece of foam tape from the roll about 3" long (3" x 2"). ![]() And put a piece of foam down to help the "cut". ![]() And pressed like crazy. There were muliple tries here and finally I used a rolling pin to roll and roll and roll ... and roll and found the blades are still not sharp enough: ![]() The tool did a good enough job that I just had to chase behind with a razor blade to finish up the task. I guess that makes it a failed project since I needed to manually finish cutting them anyway... but I have 4 more cars that need this treatment so it will be perfected. At 7 or 8 bucks per clip just to get the seal I figured this is a better way to go and next time maybe my tool will be perfected so I can just stamp out new seals instead of having to figure out the measurement again. If anyone cares, the seals are 1.00" x 0.75" with a 3/8" square cutout in the center. Factory foam is 3mm, Armaflex is 1/8" thick. rich
#16 |
Never compromise.
#17 | |
Type 1 King
Thanks for this great thread, I'm about to attempt removing the rear window trims and replacing them with some from a lower mileage vehicle since mine have been completely destroyed by the sun as you can see:
![]() ![]() ![]() ![]() ![]() I also ordered all new clips lol. But this is the clip im most worried about: ![]()
Type 1 CAI NA and DR's full interior = 14.5 @ 94 MPH My Legend = http://youtu.be/XimYbO6fvRs |
#18 |
What the Diff
Thank you rich for the write-up. And I thought I was smart with twisting the tabs that hold my skirt on my Civic.
I suspect this is how my older Legend ended up with water in the trunk every time it rained. And when I put on the brakes, a flood would come under the back seats and wash my carpet. But now that I think about it, I don't remember if the hoses were clogged from the sunroof ![]() |
#19 |
Bump for one of the most helpful DIYs on the forum. I just forwarded this to another member whose paint people we suspect "disturbed" his trim and now his trunk and audio system are getting wet from the wonderful weather we are having as of late!
![]() Thank you Photobucket for making the pictures available again!!! ![]()
The Mad Scientist!! ![]() |
Rear windshield molding/trim | soloist | OEM Parts | 0 | 04-24-2013 03:56 PM |
Circular clip removal | Nevada Ray | 1st Gen. Legend General Discussion | 3 | 02-14-2013 06:32 AM |
one more time - windshield moldong clips (front & rear) | Biggg72 | The Water Cooler | 8 | 08-16-2012 07:20 PM |
Windshield and Rear glass Moldings | Legendcpe35 | OEM Parts | 7 | 07-19-2011 08:15 PM |
