Old 12-06-2021, 07:44 PM   #21
Ka9guy
Ka9guy is on a distinguished road
After a lot of research I found a solution for the 1996-1998 rl brake calipers and upgrading them the 1999-2004 rl has different front knuckles the front calipers fit
honda accord 2003-2012
acura cl 2001-2003 and type s
acura tsx 2004-2014
acura tl 1999-08 base and 2002-2003 to type s
Sent from my SM-N950U1 using Tapatalk
Ka9guy is offline   Reply With Quote
Old 12-06-2021, 08:05 PM   #22
Ka9guy
This set up will work on a first gen RL but you will have to find the wheels that will clear them a 04 TL weal will not maybe with a spacer maybe the o5 roter will not fit it has a wider 5x120 bolt pattern you need to find a 5x114.3 bolt pattern I have seen people put Nissan 350z brimbo rotor on a 2003 accord with a center ring and that worked
For the weels try looking for a low ofset wheel the closer to -0+ the farther that will be away from the caliper so tl rims are +45 mm away from the senter of the wheel if that makes sense
Build thread for 2nd gen Lengend K sport coilovers on a 1st gen RL... CarbonGray3.5 1st Gen. RL Performance Enhancements 30 04-26-2013 05:38 AM
DIY: 1st Gen Acura RL Instrument Guage Cluster LED Bulbs (thnx to 97RLer) G3Silver First Generation RL (1996 - 2004) 4 08-05-2010 03:36 AM
1st Gen RL Alternator needs DrDave 1st Gen. RL General Discussion 3 01-15-2010 08:01 PM
4piston 2nd gen RL calipers on 1st gen RL OLD_HATCH 1st Gen. RL Performance Enhancements 16 11-06-2009 02:52 AM
