Old 02-27-2011, 05:16 PM   #1
CarbonGray3.5
2004 Carbon Gray 3.5
CarbonGray3.5's Avatar
CarbonGray3.5 is on a distinguished road
Default 1st gen Acura RL brake options
What are my options to upgrade the brakes on the Acura. I've done a little research, but haven't come up with too much yet, so I figured I'd ask the Acura gurus.
So, I'd like to upgrade the brakes and such on the car, but I don't want to spend a fortune doing it. I'd love to pick up a set of the 3G TL BREMBOs but also curious to see what else it out there and I'd like to upgrade the rotors as well and stainless steel lines are easy to install, but wanting to get people's opinions about those as well.
I figured since I'm about to paint the car and do the whole front end conversion, and install the new wheels, I might do it all now including brakes
I'm your Loving Neighborhood Asshole!
2004 Carbon Grey Metallic Acura 3.5RL with Navigation... the last of the good RLs
CarbonGray3.5 is offline   Reply With Quote
Old 02-28-2011, 06:20 AM   #2
CarbonGray3.5
Really... no one?
Old 02-28-2011, 06:01 PM   #3
B+O
RIP Fut-diesel
B+O's Avatar
well what do you want to step to? anything acura is going to be Custom, But there's some companies out there with some relatively cheap BBKs
Old 03-06-2011, 06:01 PM   #4
CarbonGray3.5
I meant using parts from other Hondas / Acuras and making a custom setup.
Such as I read the other day the Odyssey rotors are the same as RL rotors and such and could I use a 3G TL Brembo kit on my RL...
Things like that.
Old 03-06-2011, 08:47 PM   #5
B+O
RIP Fut-diesel
B+O's Avatar
either you could upgrade your calipers to the EDM KA9's with dual pistons and swap in the 99-04 Big Rotor with the bracket for it, or you can just swap in the bigger rotor... gotta make sure to get the bracket for your caliper though. 12" rotors and such.
MDX rotors are the same as the RL rotors apparently. You should try the EDM calipers, if you can get them. I don't now if JDM used twin piston calipers or not.
Old 03-07-2011, 08:03 PM   #6
CarbonGray3.5
What bracket are you talking about?
As for the EDM calipers, I'll look into them. Thank you again!
Old 03-09-2011, 08:56 AM   #7
OLD_HATCH
OLD_HATCH is on a distinguished road
How much you looking to spend?
Its gonna cost a good chunk for custom. If your lucky nd thr TL brembos will bolt on, then it'd be a matter of finding an oem rotowithe the correct diameter and offset.
OLD_HATCH is offline   Reply With Quote
Old 03-12-2011, 06:38 PM   #8
onthe3rdday
onthe3rdday's Avatar
onthe3rdday is on a distinguished road
Things like that.
They wont bolt on...
onthe3rdday is offline   Reply With Quote
Old 03-13-2011, 06:45 PM   #9
CarbonGray3.5
^^^ WELL... Balls.
And I don't want to break the bank, but a couple hundred $500-$700 would be fine.
Old 03-18-2013, 04:24 PM   #10
boostedgman
Real Name: Matt
boostedgman is on a distinguished road
you ever figure anything out, as far as larger OE brakes?
boostedgman is offline   Reply With Quote
Build thread for 2nd gen Lengend K sport coilovers on a 1st gen RL... CarbonGray3.5 1st Gen. RL Performance Enhancements 30 04-26-2013 05:38 AM
DIY: 1st Gen Acura RL Instrument Guage Cluster LED Bulbs (thnx to 97RLer) G3Silver First Generation RL (1996 - 2004) 4 08-05-2010 03:36 AM
1st Gen RL Alternator needs DrDave 1st Gen. RL General Discussion 3 01-15-2010 08:01 PM
4piston 2nd gen RL calipers on 1st gen RL OLD_HATCH 1st Gen. RL Performance Enhancements 16 11-06-2009 02:52 AM
