Old 04-21-2012, 10:09 AM   #11
BluBrett
Real Name: Brett
Send a message via Skype™ to BluBrett
Did this DIY on my passenger side door last week. Broke both of the plastic clips > and strangely, after reinstalling I still have a bit of a squeak at night. Both of my front detent rods pop a couple times but I assume that's just because they're so worn. I'm going to take my door panel off again and try greasing it up more, and also find out why my door sounds tinny all of a sudden.
Previous | 1995 Legend Sedan | Canterbury Green | Type E
Current | BMW M240i | Mineral White | Coral Red
Old 04-21-2012, 10:14 AM   #12
Open and close the door a few times with the detent rod removed, the squeaking could be the hinges. Clean thoroughly and look closely for any cracks on the rods, that will cause the popping. And make sure you're using a thick grease, thin grease and/or sprays will not get the job done or at best will not last long.
Old 04-21-2012, 06:02 PM   #13
Both of my front detent rods pop a couple times but I assume that's just because they're so worn. .
As an FYI, once the detents are really wore, there is no amount of grease
that will bring it back to working smoothly. Get some quiet ones from the rear doors at the JY as they are all the same.
Old 04-21-2012, 07:14 PM   #14
You can also interchange left and right sides, if needed, by removing and swapping the plastic covers on them.
Old 04-21-2012, 07:47 PM   #15
Are the coupe and sedan ones the same as well?
Old 04-21-2012, 08:05 PM   #16
Nope.
Old 04-22-2012, 04:54 AM   #17
Originally Posted by Quaraxkad View Post
Nope.
The ones that I've removed from coupes are exactly the same as the sedan ones. Same bolt pattern, same rod length, etc.
Old 04-22-2012, 05:26 AM   #18
In that case it may just the plastic covers that are different, like the difference from left to right, because they have different part numbers. Though they do look slightly different in the drawings, but those are just drawings!
Old 04-22-2012, 07:08 AM   #19
Different part #'s, but the same part.
I checked my collection just to make sure.
Old 04-22-2012, 07:12 AM   #20
4HondaOwner
Premium Gas Only
4HondaOwner's Avatar
Real Name: Kevin A
I checked my collection, and you have three more than I do.
hgeez:
7-1-2022 * 94 LS Coupe 6 Speed 344,151 miles * June 2022 miles driven = 43
Rear motor torque rod egamI_rorriM 1st Gen. Legend General Discussion 20 12-29-2009 06:46 PM
hows this tie rod? hotstartup 2nd Gen. Legend General Discussion 5 12-18-2009 05:33 PM
Connecting Rod Breakage Explained Nine Four One The Water Cooler 0 11-26-2009 04:14 PM
Can't find ROD BEARINGS! "Chopped" 1st Gen. Legend General Discussion 11 06-22-2009 03:23 PM
