Old 02-25-2019, 05:18 PM   #1
Legend to Grave
Love that ride!
Legend to Grave's Avatar
Real Name: Eric
Legend to Grave is on a distinguished road
Default Has Legend to Grave gone mad?
Originally Posted by Legend to Grave View Post
I like that "chrome" look more and more as it reveals itself with the patina of age..... At least that's one car part that shines with age instead of rusting!
'93 Legend Sedan - Original Owner
"Me" and "Mini Me"
Legend to Grave is offline   Reply With Quote
Old 02-25-2019, 06:14 PM   #2
Red Calipers with RL BBK?? You're living on the edge....
2016 Florida New Years / White Christmas Meet
Old 02-28-2019, 01:02 PM   #3
Legend to Grave
Love that ride!
Real Name: Eric
Front brakes:
300 mm x 28 mm Brembo rotor compatible with the RL ‘99 to ‘04 (looked up for a ‘02 RL)
RL brackets from Alan Jackson
One of the front OEM type 2 calipers (2 piston) turned out to be no good and needed replacement. Since time was short I got a set of remanufactured RL calipers compatible for an ‘02, the older type 2 caliper was not available.
I replaced the rear rotors as well with standard size Brembo.
Of course pads all around.
My guy insisted on spraying the calipers/brackets red. The rears had to be cleaned up with a wire grinder. We walked around the yard him showing off all the red calipers on old SUVs and pickups. His old truck also had a big smiley face visible from the back on the big universal joint at the back axel. There was a late model Mercedes sports type sedan with red calipers, so I accepted the “red” as opposed to a more subdued “black” that I was thinking of. All this was a spur of the moment thing. Turned out nice!
My front type 2 calipers and brackets were returned as the core and I was left with the “new” RL brackets.
"Me" and "Mini Me"
Old 02-28-2019, 04:16 PM   #4
You should have let me know. I have some nice rehabbed sets of Type II dual piston calipers available.
Old 02-28-2019, 08:25 PM   #5
Captain Slow
Ken
Captain Slow's Avatar
Captain Slow has a spectacular aura aboutCaptain Slow has a spectacular aura aboutCaptain Slow has a spectacular aura about
Nice. How are they on those big stops from 120+?
Captain Slow is offline   Reply With Quote
Old 03-15-2019, 12:44 PM   #6
Legend to Grave
Love that ride!
Real Name: Eric
Worth a conversation, but not a post. Will be seeing you soon in Maggie Valley!
"Me" and "Mini Me"
Old 03-15-2019, 12:47 PM   #7
Legend to Grave
Love that ride!
Real Name: Eric
Since I replaced the brakes, every time I need to stop short when I’m cruising at 120+ mph my back tires lose contact with the asphalt!
"Me" and "Mini Me"
Last edited by Legend to Grave; 03-15-2019 at 01:02 PM. Reason: Using phone to post which leads to typo errors
Old 08-22-2019, 01:43 PM   #8
Legend to Grave
Love that ride!
Real Name: Eric
Ok, I cheated on the above mentioned brake job by using type 1 front calipers because at that time I couldn’t get reman type 2 replacements (1 of the front calipers was a bit too oxidized and not working 100%).
So just got in a set of type 2 front calipers from Alan and got them swapped in today along with the new EGR valve (tired of code 12’s and the temporary fix of drowning the moving parts with lubricant spray was just that, temporary). A little touch up and another coat of red paint noted:
"Me" and "Mini Me"
Noticed a little bit of oil coming from vac line while isntalling SRI. Grave concern? scheibler 2nd Gen. Legend General Discussion 0 08-14-2013 05:12 PM
I can't get a break. Hit a shallow grave. The Crowing 2nd Gen. Legend General Discussion 28 11-02-2009 03:54 AM
