#31 |
Alright, I got some pics of the half shafts I have, and you are right about the splines in them.
On top, 1990 MT half shafts. On bottom, 1988 AT half shafts ![]() Splines in the MT ![]() Splines in the AT ![]() So it looks like you're gonna need the MT drive shafts for the passenger side. And I thought all drive shafts were the same.
My Build Thread Oh my gawd That jar better blow me twice and cook breakfast for $1000. |
#32 |
Real Name: Rowdy
IM lookin for a 5 speed tranny for my g1 as well...if anyone has one i want it...even if it needs attention...want to get rid of automatic
#33 |
What about bypassing the vehicle speed sensor when doing that tranny swap?
#34 |
ihate city officials
those pictures james just posted are correct.
i lost my digicam with all the pictures in it, but i took similar pictures.... before and after... i had to have the bearing carrier swapped from one half shaft to the other. i had to go to a specialty driveshaft shop to get it done. was like 20 bucks to do it.
#35 | |
![]() Quote:
Why would you need to bypass it? Just wondering. |
#36 |
Could u tell me how to bypass the Vehicle Speed Sensor on my 90 Legend. After doing my auto to manual trans swap, everything works fine except my check engine light comes on after reaching certain speeds. Help me plz. Thanx!
U can reach me at:zhinirein@optonline.net or zhinaez@gmail.com |
#37 |
Are there any better step by steps?
#38 |
JDM Ka3 owner
Real Name: Karl
Just out of curiosity,
If I bought a 2.5l manual sedan out of a recking yard, and I have a coupe, is everything bar the ECU the same? (loom, gearbox, trans mounts?) |
#39 |
Mechanically the same (they'll mount). I feel like the gear ratios are different between 2.5 and 2.7 though. Wire harness is slightly different because the ECU is different. But if you're just looking at a transmission swap you should be good
#40 |
The Mad Scientist
Real Name: Taylor
2.5 gear ratios are shorter and closer ratios
No one's ever gotten noticed from catching the small fish. |
