Old 06-16-2010, 09:12 PM   #1
maxXspeed
Meet a Legend
maxXspeed's Avatar
maxXspeed is on a distinguished road
Angry HELP PLEASE on installing cd player
i think i am loosing my mine but i can not connect my antenna to a power supply so it will extend up when the radio is on. i have a alpine 9811 and everything is up working fine. From the rear of the cd player i have the blue wire that says "P. INT" which i assume its for power antenna, but were the hell is it on my car harness?
RIP Legend...
maxXspeed is offline   Reply With Quote
Old 06-16-2010, 09:17 PM   #2
the blue wire on the alpine unit should connect to the blue wire on the Honda harness. that's all there is to it. all of the other wires are color matched, so is the antenna.
Old 06-17-2010, 03:03 AM   #3
antik
I blame the M3.
antik's Avatar
+1 - there are two antennas though: make sure you use the wire for the mast antenna as opposed to the rear glass antenna.
You are using an adapter harness, right?
'95 Auto L Sedan [SOLD]
Old 06-17-2010, 05:49 PM   #4
maxXspeed
Meet a Legend
maxXspeed's Avatar
yes i am to the wire harness. is the power antenna connected to the cars oem wire harness. i see a light green cable not connected.
RIP Legend...
Old 08-31-2010, 02:09 PM   #5
loveeenunuu
loveeenunuu's Avatar
Real Name: samantha nickname nunu
loveeenunuu is on a distinguished road
Sorry, I didn't want to create another thread and cluster this section up. I have a similar question. I am a total noob at this.
Just bought a new headunit and got a Scosche HA02 harness at best buy. I color-matched everything to the HU's wire harness and crimped the wires together. Finally plugged it up to the car's radio harness and nothing turns on at all when I turn the key.
Am I doing something wrong here? Is the adapter harness the wrong one? They said it should work for a 91-95 Legend. I checked the fuse on the HU and it's fine. Any input would be great. Thanks in advance.
loveeenunuu is offline   Reply With Quote
Old 08-31-2010, 02:15 PM   #6
DevanTheDude
Ninjaneer
DevanTheDude's Avatar
DevanTheDude will become famous soon enoughDevanTheDude will become famous soon enough
There's also a fuse in the underdash fusebox, and one in the underhood fuse box. May be worth checking those
DevanTheDude is offline   Reply With Quote
Old 09-01-2010, 06:09 AM   #7
antik
I blame the M3.
antik's Avatar
The underdash fuse is your best bet.
Poor harness assembly could be to blame too... not hating but noobs typically aren't instructed about the proper way to wire these harnesses up.
Old 09-01-2010, 12:21 PM   #8
I agree on the underdash fuse as the second place to look. Make sure those connections are really good (oh and cheap Wally World and similar connectors typically stink). I've had issues in the past with the crimp kind even using the correct tools. I'm now a wire twisting, soldering, electrical taping then heat shrink tubing kind of guy.
Old 09-01-2010, 01:53 PM   #9
What kind of HU did you purchase? Was it a cheapo one? I've seen them be bad out of the box before (the cheap ones, more specifically DUAL brand). Way more likely that it's a fuse or bad connection on the harness, but if all other troubleshooting steps fail you should take that into consideration. It's very easy to test if the head unit is functional or not just by touching 3 of the wires directly to the battery. This would require you to undo your crimps (basically cut the wires, unless you used crimps that can disconnect which I do for this reason).
Old 09-01-2010, 07:18 PM   #10
loveeenunuu
Checked the fuses under hood and under kick panel. All good.
HU turns on when I connected it to my BF's car via his harness.
I have an Alpine CDA9856 HU.
I'm having the same issues as this person
http://www.acura-legend.com/vbulleti...85/index2.html
Thanks for all the help guys. Greatly appreciated.
Having problems installing my new tranny burke753 2nd Gen. Legend General Discussion 8 03-26-2010 09:19 PM
DIY: G1 TL CD player in G1 Legend. 18 characters long First Generation Legend (1986 - 1990) 29 03-11-2010 10:10 PM
Installing the MLS bar Roger 2nd Gen. Legend General Discussion 16 09-28-2009 04:51 PM
Installing Head Unit Jaysus! The Water Cooler 12 08-31-2009 01:32 PM
