Old 04-28-2022, 12:43 PM   #1
Beeze
O.G. in O.C.
Beeze's Avatar
Real Name: Brent
Beeze is on a distinguished road
Unhappy Engine died on Freeway
I was driving my 90LS MT Sedan on the freeway yesterday after it had sat for a while. When suddenly I heard a "pop whoosh" sound from the passenger side engine bay and the engine died, I lost power steering and braking. Once I got the car pulled over, I tried cranking it but I was not getting any compression, so it would not start. I had it towed home and there is a serious oil leak from the passenger side. I checked and all the belts are intact. Any ideas or troubleshooting suggestions?
Beeze is offline   Reply With Quote
Old 04-28-2022, 07:04 PM   #2
This sounds very bad.
Broken timing belt bent the valves bad.
Or rod through the block bad.
What symptoms led you to conclude you were not getting any compression?
You lost power steering and power braking simply because the engine died.
As for troubleshooting, first check the timing belt for breakage or slippage.
Look for a hole in the block in the vicinity of the oil leak.
Car died need help 94l 2nd Gen. Legend General Discussion 15 12-16-2015 05:54 PM
Help please! My car died :( 93type2 2nd Gen. Legend General Discussion 2 04-06-2011 12:08 PM
my coupe hesitating on freeway???? BABO_C27A1 1st Gen. Legend General Discussion 12 03-19-2010 11:24 PM
Engine died houston90legend 1st Gen. Legend General Discussion 20 11-30-2009 03:57 PM
Tire popped on freeway and pulled out wire harness in my lude! filmshoot The Water Cooler 9 08-04-2009 03:06 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
