Old 09-16-2020, 11:50 PM   #1
MIZEMIKE
MIZEMIKE is on a distinguished road
Default HELP with Aftermarket Timing Components!
Hi everyone, I am needing to replace my timing belt, water pump and tensioner pulley on my 1992 Legend LS Sedan with 57,150 all original car.
So my question is, has everyone ever used aftermarket timing components, such brands (found on Amazon.com) as Dayco, Gates, Continental, DNJ, MOCA, ACDelco, Evergreen, GMB, ITM & ContiTech and there is the "timing belt only" by Bando with great success, meaning you got the same mileage or age as with OEM Honda parts??
That being said, I would "LOVE" to replace all my timing components with HONDA brand parts, but as you know Honda has quite manufacturing parts for these Legend's, so you are left with NOS (New Old Stock) parts and if you're lucky to find them, there price is sky high!😒
So if anyone has any ideas or any reviews on which aftermarket components to use it would be greatly appreciated!😊
Thanks!
MIZEMIKE is offline   Reply With Quote
Old 09-17-2020, 05:26 PM   #2
95legendcp
95legendcp is on a distinguished road
The last two timing belt changes I used the GATES TCK193. Timing belt and tensioner (27.99 at rock auto). Both were 100k mile intervals. I use Aisin or Atsugi water pumps, this water pump might be hard to find. I also use this seal from rock auto MAHLE C31208 (.84 cents) goes between water pump and thermostat housing.
1995 Acura Legend LS Coupe 6spd. JDM TYPE II, 6spd trans (lower mileage). 5-spd flywheel, EXEDY clutch. Fut MLS strut bar, H&R springs,Monroe shocks,ADDCO Front & Rear sway bars, FUT Tie Bars,SPC ball joints, MOOG Front Upper control arm anchor bolts, EBC ULTIMAX Rotors f+r,AKEBONO ceramic pads f+r. Poly mounts(60a). BLACKEND damper.18x8 40 offset KONIG Verdict. BF GOODRICH G-Force T/A KDW.
95legendcp is offline   Reply With Quote
Old 09-22-2020, 01:18 AM   #3
MIZEMIKE
Thanks for the info.
I will check on the Gates Timing Belt Kits and also on the Aisin or Atsugi water pumps.
Thanks again and please be safe during this trying time.
JDM suspension components for KA9 chassis trip6kidd 1st Gen. RL Performance Enhancements 0 11-26-2014 04:14 PM
a few front suspension components devolution OEM Parts 2 09-30-2011 07:37 PM
FS: G2 Electrical Components/Controls ari_one OEM Parts 11 01-07-2011 08:59 AM
Any 3.5 owners swapped TII components soloist 1st Gen. RL General Discussion 30 11-22-2010 04:33 PM
Car Stereo project q's, components MXHalofan Audio and Other Electronics 15 06-05-2009 10:48 PM
