Old 11-17-2018, 05:51 PM   #61
EGR code on CEL only indicates that the valve is not opening: nothing to do with detecting flow past the valve. I have had luck WD40'ing the valve shaft and got it to stop throwing the code. If that doesn't work, I have good used EGR valves available.
2016 Florida New Years / White Christmas Meet
Old 11-17-2018, 07:27 PM   #62
Branden
Branden's Avatar
Branden is on a distinguished road
Yep I understood that going in. Was hoping a good cleaning wood get that valve working right but I guess not. I will message you Alan
1995 Legend L Coupe
1991 Legend LS Sedan
Branden is offline   Reply With Quote
Old 11-17-2018, 08:47 PM   #63
WD40, PB Blaster, Free-All, any rust penetrating lube will sometimes helps free it up, Ive saved a few of them doing that trick too. Once it is free or even as prevent maint. Hit the valve shaft with a little Remoil...it's suspended teflon and nothing will stick to it, also works well on power antenna masts to keep them moving freely, even door hinges, locks, window channels etc. Obviously clean the area you are gonna coat first, but yeah, that stuff works wonders, I use that pretty often now that Ive learned about it.
Old 12-30-2018, 10:00 AM   #64
Branden
Branden's Avatar
New hood courtesy of Alperovich. Its got some damage but much better than mine. Gonna wrap it in black vinyl. Also got a new driver headlight in
Sent from my iPhone using Tapatalk
1995 Legend L Coupe
Old 01-28-2019, 02:36 PM   #65
Branden
Branden's Avatar
Threw a little bass in the trunk and wrapped the hood in black vinyl
1995 Legend L Coupe
Old 01-29-2019, 05:13 AM   #66
lgnd4u2nv
lgnd4u2nv's Avatar
Real Name: Richard
lgnd4u2nv is on a distinguished road
Nice work getting this thing back on the road and looking beautiful!
Sedan Sold in 2009. Coupe coming soon??
lgnd4u2nv is offline   Reply With Quote
1995 Black/Black GS Auto Sedan 4HondaOwner "Not Mine" 22 08-13-2013 05:46 PM
FS: Time to go: parting out 1995 LS Coupe 6 speed, White on Black wrecked in the rear kotetu Parting Out 147 08-26-2010 08:53 PM
1995 Acura Legend Coupe Black/Black in CA Lsportline43 "Not Mine" 6 12-10-2009 02:34 AM
FS: 1995 Black on Black LS sedan in Atlanta DJBacon06 Legend 12 08-08-2009 05:54 AM
