Old 05-24-2019, 01:47 PM   #11
jgoeke
Real Name: joe goeke
jgoeke is on a distinguished road
I did not realize that the 1st. Gen TL has a longitudinal engine. I’m guessing the 2nd gen has a sideways engine?
Yes, this is my understanding. More here also:
https://en.wikipedia.org/wiki/Acura_TL
I'm taking the heads off mine to see if there is anything to see before trying to pull the whole thing....
jgoeke is offline   Reply With Quote
Old 05-28-2019, 12:06 PM   #12
I have done both removing engine and trans from the top and dropping the front subframe with engine and transmission.
It is easier to drop the subframe as that is the reverse of how the vehicle was built. I would highly recommend building some sort of cradle for the cradle. SR5Guy and myself have built them using a pallet with wheel dollies bolted to the bottom. You can use 2x4's stacked to rest the tail shaft of the transmission onto it. Once removed you can then wheel it around or pick it up using an engine hoist.
Make sure you disconnect all the wire harnesses near the passenger side firewall as well as the power steering lines and all vacuum lines. Drain the coolant and remove the upper and lower radiator hoses as well as the rear heater hoses. Remove the CV axles from the transmission side, it's easier if you remove the lower ball joint from the lower control arm, you can then let the cv axle hang and secure it with some bungee cords to keep it from flopping down. It helps to mark vacuum lines and any wiring harnesses with masking tape and put an identifying letter or number on the tape so you know where each one goes.
Good luck.
Old 06-06-2019, 07:39 PM   #13
jgoeke
Fantastic info! Thanks!
Good luck.
Old 06-14-2019, 01:26 PM   #14
jlstewart3
jlstewart3 is on a distinguished road
Would you suggest dropping it if you don't have a lift and only jack stands?
jlstewart3 is offline   Reply With Quote
Engine pull Alperovich Legend Builds 93 02-18-2014 01:45 PM
Pull Engine or Engine & Tranny?? Aking 2nd Gen. Legend General Discussion 20 03-20-2012 01:37 PM
Super Cool Engine Pull Pics and Vids!! (56k You Crazy!) Reboticon 2nd Gen. Legend General Discussion 21 07-24-2010 02:06 PM
U-Pull it A** F*** alittlethin The Water Cooler 21 06-04-2010 11:56 AM
What tools needed to pull a junkyard engine? LegendNoob 1st Gen. Legend General Discussion 18 04-10-2010 08:50 PM
