Old 04-07-2021, 11:50 PM   #1
FastFreddy777
FastFreddy777 is on a distinguished road
Default 93 acura legend No Start when engines warm
while parking i drove off the side walk,my driver side tire fell off the curb.The curb was only about 6 inches tall.The car died and wouldnt restart.I TRIED ABOUT 20 MIN LATER AND IT STARTED RIGHT UP.And now when ever I shut it off after driving at normal temp.It wont start.But as soon as it cools down it starts fine.Can someone help me in the right direction please.And its not putting out any codes and no check engine lights.
FastFreddy777 is offline   Reply With Quote
Old 04-08-2021, 09:08 AM   #2
paulo57509
paulo57509's Avatar
paulo57509 is on a distinguished road
1st Gens have a single main relay where the ignition and fuel systems are turned on with the ignition switch. It sounds like your car is having symptoms of a bad relay (heat related).
I don't know if 2nd Gens have a single or separate relay for fuel and ignition. If you can, by process of elimination determine if you're not getting spark or fuel when you have a no-start condition, it will narrow it down some what.
'87 L-Coupe 5-Speed
Stock; Few Mods
445K Miles - original engine and drivetrain.
paulo57509 is offline   Reply With Quote
Old 04-08-2021, 11:14 PM   #3
FastFreddy777
thanks Paulo. I was thinking that also when this first started.Especialy since it just started after dropped the front right tire off the curb.I checed that out the first thin,with an omh meter.and it checked out ok.And the car will start when the engine cools down.And runs fine.So I have a temp.sensor gauge and a engine cooling system sensor coming tomorrow I`ll try that and go from there.Thank you again for your help.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
So why are we not swapping J-series engines into the Legend? whats77inaname 2nd Gen. Legend Performance Enhancements 78 04-29-2015 07:23 PM
Intermittent no warm start kconatymd 1st Gen. Legend General Discussion 3 04-29-2014 01:07 PM
how long should a legend normally takes to warm up? belial 2nd Gen. Legend General Discussion 16 01-08-2014 08:34 AM
FS: 96-04 Acura RL engines (hello 3.5 swap!) GreekPower OEM Parts 8 08-05-2012 11:34 PM
1988 acura legend coupe wont start after engine warms up wesmagyar 1st Gen. Legend General Discussion 10 03-20-2011 04:27 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
