Old 04-25-2019, 06:30 PM   #1
vsouvann
Real Name: Vin
vsouvann is on a distinguished road
Default High and Rough idle (unstable) HELP!!!
I live in San Diego. I took my 1987 Legend Sedan to get Smog Tested, but the tech guy said that it wouldn't pass because the idle was rough and too high, around 1500 RPM. He said that it's gotta be under 1000 RPM. I tried adjusting the throttle cable and played with the flat screw by the intake unit with No Luck. When the engine warms up, it starts to bounce up and down.
Any advice is much appreciated, thanks.
vsouvann is offline   Reply With Quote
Old 04-25-2019, 07:08 PM   #2
The first thing to check is the coolant temp sensor.
Here's a thread about it:
http://forums.acuralegend.org/high-i...8.html?t=27968
Old 04-25-2019, 08:01 PM   #3
vsouvann
Real Name: Vin
Thanks,
I was reading the thread earlier, but where exactly is the water coolant sensor? I will get a new one and replace it.
Old 04-25-2019, 08:08 PM   #4
vsouvann
Real Name: Vin
I think I just found it. Is it under the distributor cap?
I also read something about the FIV. How do I check to see if that's good or bad?
Old 05-04-2019, 02:33 PM   #5
vsouvann
Real Name: Vin
Thanks for your help JKLedbetter. I finally got it done.
Old 05-05-2019, 07:39 AM   #6
stephen
stephen is on a distinguished road
The problem you have usually comes from the fast idle valve (Honda part number 16500-PL2-901 no longer available). It's a vacuum bleed that is controlled by coolant temperature.
Commonly all that is needed is to bleed the cooling system.
I think Eric the Car Guy has a video on this.
stephen is offline   Reply With Quote
Old 05-05-2019, 08:02 AM   #7
stephen
This is the Eric the Car Guy video
https://www.youtube.com/watch?v=L788jKEVblY
Old 05-09-2019, 08:53 AM   #8
stephen
So what was the fix?
Occasional rough idle Patmka8 2nd Gen. Legend General Discussion 2 11-02-2014 03:22 PM
Idle unstable Peabodyn 1st Gen. Legend General Discussion 9 07-20-2014 01:38 PM
rough idle but only in drive Al Taylor 1st Gen. Legend General Discussion 8 03-11-2013 11:23 AM
Rough idle stall fslaugts 1st Gen. Legend General Discussion 9 10-21-2012 10:07 PM
Rough idle symptoms NorCaLegend 2nd Gen. Legend General Discussion 40 01-15-2011 08:28 PM
