Old 10-13-2014, 06:29 PM   #1
Rsanders24
Rsanders24 is on a distinguished road
Default Crank...No Start after installing new battery
Ok...so my 94 Legend has been sitting for about 4 month because the crank pulley seperated and I haven'r had the time to work on it. The battery was shot from just sitting there so I bought a new battery put it in just to run the engine for a while (the alternator pulley is all that came off.) Well after I hooked the battery up I heard a click. I assumed this is normal but when I turned the key to on and I let it sit for about a min the CEL never went off so i tried to start the car and it just turned over like no ingition/no fuel. After about 5 mins of trying to start and taking like 30 second rest after about 6 seconds of cranking i hear another click (sounds like it coming from the drivers side footwell) and the CEL goes off and she fires right up. Please help....
Rsanders24 is offline   Reply With Quote
Old 10-13-2014, 06:37 PM   #2
ThirstyTree
ThirstyTree's Avatar
Real Name: Mark
ThirstyTree is on a distinguished road
Tighten battery cables, or jump start the car. If a jump works, your battery does not have a full charge from the store or, more likely, its a defect. Make sure everything is hooked up tight first.
ThirstyTree is offline   Reply With Quote
Old 10-13-2014, 06:42 PM   #3
Rsanders24
Battery is fine...car turns over no problems...it has something to do with the CEL...as soon as it goes off it starts right up. And when i check for codes no codes are shown...light doesn't flash...
Old 10-13-2014, 07:32 PM   #4
ThirstyTree
Real Name: Mark
Check main relay under dash. Common problem. Another way to tell if its the relay is to listen for the fuel pump when someone else cycles the key. If you dont hear a whir from the pump priming, your main relay likely is bad.
Old 10-13-2014, 07:58 PM   #5
Rsanders24
Thanks! I hope that's it....I'll check that tomorrow evening...
will not crank or start ZACH 1st Gen. Legend General Discussion 31 04-14-2012 10:28 AM
battery light stays on--battery fully charged, car won't start. blackeagle229 2nd Gen. Legend General Discussion 8 01-17-2012 03:01 PM
No Crank No Start...HELP!!! Aking 2nd Gen. Legend General Discussion 28 06-13-2011 03:41 PM
A way to start your car without a battery! filmshoot The Water Cooler 9 06-11-2010 07:47 AM
