Old 09-01-2012, 08:48 AM   #1
MasTeR.LeGenD
1........LOVE
MasTeR.LeGenD's Avatar
Real Name: 95 LS 3.5hybrid dropin clutches
MasTeR.LeGenD is on a distinguished road
Default Quick response start up issue?
Ok car wouldnt start made the loud clicking from the hood. Jumped it and it started so starter is good. Next drove for 10 mins parked and car started again so dont think its alternator? While car was on I disconnected the negative terminal as im almost sure this is the test that if you disconnect this terminal while the car is on and it dies it is an alternator problem.. Am I correct is this probably a dead battery issue...I dont drive the car that often in the summer so what do you guys think last day I drove was last monday.
Thanks
MasTeR.LeGenD is offline   Reply With Quote
Old 09-01-2012, 08:58 AM   #2
That test is only not safe but its not the proper way to test an alternator. You need to check the battery voltage when the car is idling.
Old 09-01-2012, 09:06 AM   #3
If you pulled the terminal and it died prob the alternator isn't charging. It's best to fully charge The battery via a charger then use a multimeter to watch the charging voltage. Pulling the termimal like that could cause a voltage spike and ruin sensitve systems.
Old 09-01-2012, 09:08 AM   #4
MasTeR.LeGenD
1........LOVE
Ahhhh shit think i fucked something up? The car didnt die stayed on...
Old 09-01-2012, 09:21 AM   #5
the_professional
proFRESHonal
the_professional's Avatar
Real Name: Sean
the_professional will become famous soon enough
Send a message via AIM to the_professional
I'd suggest getting a multimeter so we can help out. I would check the alternator under load and look at battery voltage throughout (eg. idling, 2K, 3K, under full load, etc.).
FOR SALE - PARTS CAR: http://forums.acuralegend.org/1995-a...an-t30783.html
Keep your two cents, I ain't trying to leave you broke.
the_professional is offline   Reply With Quote
Old 09-01-2012, 09:30 AM   #6
ok, if it stayed on, then you know the alty was putting out. charge the battery and then have it tested. sitting around isn't all that great for a battery.
Old 09-01-2012, 09:34 AM   #7
Sorry my previous response was on my phone which I hate typing on. It doesn't mean you fucked anything up if the car stayed on. It means the alternator probably is charging, but like it was already stated, that test is not a safe one to do. You need a proper test that gives actual data figures. A multimeter is a good place to start, or take it down to the local auto parts place and get a free battery and alternator check.
You want to test your battery with the car not running and also the charging system with the car running. For the battery test you want to see voltage and the results of a load test. For the charging system you're mainly wanting to see the charging voltage with the car running. If your battery is below 12.6v when the car is off, but when it's on you see 14v, most likely your battery is bad. If you see 12.6v at the battery when it's off and still 12v when the car is on, your alternator is not charging.
Old 09-01-2012, 09:51 AM   #8
Sounds like your battery terminals are loose.
Old 09-01-2012, 09:55 AM   #9
your suppose to let the car run for atleast 30-40mins inorder for it to charge. I wouldnt expect it start with only 10mins worth of driving. If I were I would go to autozone and ask for a load test to make sure the battery and alternator is good. This service is free by the way.
Old 09-01-2012, 11:35 AM   #10
MasTeR.LeGenD
1........LOVE
Whats up matt where you moving to?
Went to advanced auto parts all is good with altenator yet they said battery is low or needs replacement...Car is starting well now though.
Cleaned my battey terminals....
Long start, rough idle and poor throttle response wadd3456 2nd Gen. Legend General Discussion 3 01-23-2012 06:15 PM
Another NO Start Issue.. Legend Coupe 2nd Gen. Legend General Discussion 13 02-25-2011 02:00 PM
Cold Start "Issue"? the_professional 2nd Gen. Legend General Discussion 6 01-02-2011 10:31 PM
best for engine response vinh291 2nd Gen. Legend Performance Enhancements 25 06-11-2010 06:45 AM
Server Response Time LegendGS New Member Introductions 5 06-05-2009 05:36 PM
