Old 03-19-2012, 12:15 PM   #1
ZACH
ZACH is on a distinguished road
Default will not crank or start
OK here is my problem I just got an 88 legend sedan thats been sitting for a few years and the thing will not crank or start.I get no power to the ecu or starter when i turn the key just dash lights and the check egn.light .Ive been searching and feel its a simple fix but not so simple for me.I replaced the main relay already and while checking my ingnition wires i seen wires spliced in going to a box or amp behind the center dash/console.Disconecting these did not help or change any thing.As of right now when i turn the key i hear a click from under the glovebox and get dash lights on. No fuel pump no light on ECU and no power to starter. I hope someone can help thanks
ZACH is offline   Reply With Quote
Old 03-19-2012, 01:02 PM   #2
Andyrst
Refinement Engineer
Real Name: 1993 Acura Legend Coupe LS
Andyrst is on a distinguished road
Send a message via AIM to Andyrst Send a message via Yahoo to Andyrst
Default since it has been sitting awhile
open the hood and tap the top of the solenoid of the starter and then retry the key
Andyrst is offline   Reply With Quote
Old 03-19-2012, 01:11 PM   #3
ZACH
Still the same.I can get the starter to crank if i jump the solinoid
Just cant with key the starter does not click or get power to the solenoid
Old 03-19-2012, 01:55 PM   #4
There's a ground wire that is bolted to the center top of the intake manifold. That is the ground wire for the ECU. Make sure that wire is nice and clean. Also make sure your ground wire and positive wires have a clean contact area. If that doesn't work, it sounds like the ECU is fried. A Red light will light up if you turn the key on the ignition. Also, did you replace the battery? If its been sitting around for that long, that battery is long gone and needs a replacement.
Old 03-19-2012, 03:54 PM   #5
ZACH
The red light on the ecu does not come on at all.I sure hope thats not it. I replaced the battery,and the ground looks a lil coroded but tight ill takeit off and clean it up.I checked all around for loose grounds and found none.any other sugestions?
Old 03-19-2012, 05:07 PM   #6
Hope you're looking at the right ECU, which is under the passenger seat. Forgot to mention, check the fuse for the ECU in the under hood fuse box.
Old 03-19-2012, 05:51 PM   #7
stephen
Maybe a problem with the ignition switch.
The spliced wires may go to the stereo system and probably are not important.
Probably start with a new battery and checking all the fuses.
Old 03-19-2012, 06:31 PM   #8
ZACH
Finaly got the car to crank But still no start.Replaced fuel pump fuse and srs fuse wich had a plactic fuse in its place for some reason.Still dont think im getting fuel maaybe fuel pump?
Old 03-19-2012, 07:08 PM   #9
stephen
When you turn the ignition switch on the fuel injection light should be on for a few seconds
and the fuel pump should run during that time. After turning the ignition on and off a few times, if you loosen the bleed bolt from the banjo bolt on the fuel filter, some gas should leak out if the pump is working.
Old 03-20-2012, 12:47 PM   #10
ZACH
Well i think the problem is the fuel pump i check and im getting power to it but no sound from it so next step i guess is to remove it and replce it.Now can i get it out without removing the rear seat?
And Thanks everyone for your post your help does not go on deff ears
Cant Rotate the Crank...HELP! Aking 2nd Gen. Legend General Discussion 14 08-01-2011 01:51 AM
Finding Crank TDC with no Crank pulley attached gsdreams 2nd Gen. Legend General Discussion 3 07-10-2011 03:47 PM
No Crank No Start...HELP!!! Aking 2nd Gen. Legend General Discussion 28 06-13-2011 03:41 PM
engine crank and won't start engine check light Legend95 2nd Gen. Legend General Discussion 0 12-22-2009 05:59 AM
Does Your Legend Crank But Not Start? Sticky Pls. ManOfBusiness 2nd Gen. Legend General Discussion 8 10-23-2009 05:44 PM
