Old 06-10-2011, 08:20 PM   #1
Aking
Aking's Avatar
Real Name: A King!
Default No Crank No Start...HELP!!!
I need a little help. First time this has happened on my coupe I bought a few weeks ago. It has started fine everytime with no issues, but today, I just changed the oil and flushed and filled with new Type 2 Coolant and I get in to start the car to bleed the cooling system and she wont start.
All the dash lights are on and everything works fine, but nothing when I go to ON position. Also, the door locks unlock and then lock again whenever I try and start it. Is this something with the security system? It also still has the factory radio in it which doesn't turn on.
Any ideas on what I can check?
Old 06-10-2011, 08:26 PM   #2
Do you hear a click when you turn on the key?
Old 06-10-2011, 08:37 PM   #3
Aking
Aking's Avatar
Real Name: A King!
Yes, I hear a click coming from the left side under the dash when I turn the key to the ON position. Sometimes it clicks, sometimes it doesnt.
Old 06-10-2011, 08:43 PM   #4
Aking
Aking's Avatar
Real Name: A King!
You think its the main relay going bad?
Old 06-10-2011, 08:47 PM   #5
Sbwooder
The teach
Sbwooder's Avatar
What is it doing exactly? Just cranking or nothing after turning the key? Clicking???
Chris (Mr. Wood)
Milano and Frost
<a href="http://s8.photobucket.com/albums/a49/carforever/legendspring08/?action=view&current=chrisspring08022.jpg" target="_blank"><img src="http://i8.photobucket.com/albums/a49/carforever/legendspring08/chrisspring08022.jpg" border="0" alt="Photobucket"></a>
RIP FUT
Sbwooder is offline   Reply With Quote
Old 06-10-2011, 08:58 PM   #6
Aking
Aking's Avatar
Real Name: A King!
Chris (Mr. Wood)
Milano and Frost
No cranking no nothing, just dash light, beeping noise, and my doors lock and unlock by themselves one time. No clicking like it would do if the battery was dead. When I turn it to ON to start, there's nothing.
Here's a video...
Old 06-10-2011, 09:04 PM   #7
Check that the car is in park or neutral if it's an auto.
Old 06-10-2011, 09:09 PM   #8
Aking
Aking's Avatar
Real Name: A King!
Yea its an Automatic and its in park, I even tried to putting it in N to start it, nothing. Both front wheels are off the car and its up on jack stands, but I dont think that should effect anything.
Old 06-10-2011, 09:15 PM   #9
Check the main relay.
Old 06-10-2011, 09:29 PM   #10
jay510
jay510 is on a distinguished road
Do you hear a chiming noise? Do the your turn signals flash? Does you car have a aftermarket alarm? If it does, that's probably the problem because i was having the same issue with my car and I took off the Aftermarket alarm, since then I have never had a problem.
"Legendary"
Check Out The Transformation
http://forums.acuralegend.org/acura-...4.html?t=11224
jay510 is offline   Reply With Quote
Type 1 crank pulley matchstickman600 OEM Parts 9 10-26-2011 09:38 AM
engine crank and won't start engine check light Legend95 2nd Gen. Legend General Discussion 0 12-22-2009 05:59 AM
Crank Pulley gibbsrcing OEM Parts 1 11-28-2009 09:56 AM
Does Your Legend Crank But Not Start? Sticky Pls. ManOfBusiness 2nd Gen. Legend General Discussion 8 10-23-2009 05:44 PM
