Old 05-20-2010, 10:59 AM   #1
9735RL
9735RL is on a distinguished road
Default Koni Reds for Legends fit?
My car is lowered on comptech springs and factory shocks right now. Has anyone bought the adjustable Koni Red's for the 91-95 Legend and had them put on the RL? I know that with some of the other shocks the Legend front forks have to be purchased for direct fit, but wasnt sure if these are any different.
9735RL is offline   Reply With Quote
Old 05-20-2010, 11:04 AM   #2
I am not 100% on it, but, if my memory serves me correctly, in order to use any of the shock set ups from the G2 Legend, you need a set of G2 front forks. Im pretty sure Ivan or a few other guys that know for sure will chime in.
Old 05-20-2010, 09:06 PM   #3
OneBadKA9RL
OneBadKA9RL's Avatar
OneBadKA9RL is on a distinguished road
Send a message via AIM to OneBadKA9RL
I have legend forks with the Ksports...I am going to say that they should fit, but I don't know if you'd have to custom make the seat for the spring or not.
2001 Acura 3.5RL
2004 Acura 3.5RL
1997 Nissan 240SX
VIP Modular Wheels
OneBadKA9RL is offline   Reply With Quote
Old 05-21-2010, 11:02 AM   #4
B+O
RIP Fut-diesel
B+O's Avatar
OLD_HATCH actually has them installed on his car, i will Text him and tell him to inundate you with all the information you need
They're practically a bolt on affair once you get Legend lower Forks.
Old 05-24-2010, 05:53 PM   #5
OLD_HATCH
OLD_HATCH is on a distinguished road
They are pretty much straight forward.
The fronts will need the pinch fork and the spring perch from an oem Acura Legend strut. This is because koni designs the front shock to use the oem perch on its struts which come perchless.
After that then the front normal perch will be the same as the RL stock height.
The rears are a little different. WHile koni does send perches for the rears and they bolt up to the RL with no modification needed, when placed at the oem hight they make the rear of the RL taller than the Legend.
If I rember correctly it makes the rear sit about half an inch or so higher. you will need some machining to place grooves at the proper height.
theres some more info in this thread.
http://forums.acuralegend.org/lower-...sing-t798.html
OLD_HATCH is offline   Reply With Quote
FS: Koni Reds for Sale - Toronto tonythebullet Non-OEM Parts 17 05-06-2010 07:49 AM
Koni reds for my g2 Dangerwillrobinson Non-OEM Parts 1 03-23-2010 11:48 AM
FS: FEELER: Koni Reds+H&R springs Nino418 Non-OEM Parts 23 02-16-2010 01:15 AM
FS: Eibach springs/ Koni Reds blackeagle229 Non-OEM Parts 7 12-29-2009 09:56 PM
Koni Reds (Preferably New) StimulusPackage Non-OEM Parts 7 06-27-2009 01:54 AM
