Old 06-09-2009, 12:07 AM   #1
Telion
Don't doubt it!
Default Buzzards C32A race engine
C32A Turbo race engine.
Here are the much waited for photos, in no paticular order.
http://www.newcastlelaps.net/members/buzzard1.JPG
http://www.newcastlelaps.net/members/buzzard2.JPG
http://www.newcastlelaps.net/members/buzzard3.JPG
http://www.newcastlelaps.net/members/buzzard4.JPG
http://www.newcastlelaps.net/members/buzzard5.JPG
http://www.newcastlelaps.net/members/buzzard6.JPG
http://www.newcastlelaps.net/members/buzzard7.JPG
http://www.newcastlelaps.net/members/buzzard8.JPG
http://www.newcastlelaps.net/members/buzzard9.JPG
http://www.newcastlelaps.net/members/buzzard10.JPG
http://www.newcastlelaps.net/members/buzzard11.JPG
http://www.newcastlelaps.net/members/buzzard12.JPG
http://www.newcastlelaps.net/members/buzzard13.JPG
http://www.newcastlelaps.net/members/buzzard14.JPG
Probably not 56K friendly
I cant claim credit for the fabrication, that is the customers work, however, i tune it and suggested much of the setup. It was a team effort.
How the dissy works is pretty simple, the rotor button is mounted on the cam wheel so it turns with the engine.
buzzard10.jpg is a shot of the crank trigger sensor. The actual trigger is mounted behind the crank pulley.
The 2 pulleys run a small pump, for the torque converer. It is made from a L series datsun engine oil pump.
The last 2 photos are shots of the headers we used on our N/A engine which we raced before building the turbo engine
Chris
Originally Posted by Dv8
mighty good jobe mate. Fab work is awesome, now how about we drop that in a legend?
How does the distributor work?
what are the two little pulleys on the backside for?
~TRu Hybird
We are using ross forged pistons and Argo rods the stock gear is not
suitable for endurance racing.
Chris
Originally Posted by sr79labrat
How much are those rods and pistons? What kind of stress/power/boost can they handle? Are they any good for a daily driver? You see what I am getting at dont you? How much are they goin cost me?
Thx Kyle
The rods run to about $2200 per set. We are currently around 77 cents US to the AUS dollar.
The Ross pistons you can get yourself, they are made in the US. Not sure on the price.
There is no problem with the rods, as much power as you want. I think you will find weaknesses in the engine design before you find the ultimate strength of the rod.
No problem for a daily driver but why ???
THanks for the info! So what psi did you burn through the piston? What are the limits on the rods that you have seen so far? I am curious to see what I can do w 150K miles without breaking anything serious. I want to get 400hp/ tq to the wheels reliably. Is this possible on stock internals minus the HG?
Thanks, K
Actually we use a standard honda head gasket, but we o-ring the block.
We burnt the piston @ 12psi, however there were several contributing factors.
A very hot race day, causing the engine to run hot, and a cooling system that was not fully sorted.
A slightly over exuberent tune on my part, cause by the owners constant urging.
Use of a NGK heat range 5 plug at the request of the engine builder.
Use in endurance racing, this engine did a days dyno and around 120 race miles.
Reducing the advance by 2 degrees and fitting heat range 7 plugs resulted in an engine that ran several races successfully before the overboost.
So, with carefull tuning and component selection you may get many miles from the engine, however i would order a piston kit.
Chris
I have a turbonetics T4 the smaller 1 of the 2 something like to4e. The range is 250-550 hp....I think I am barely getting in the power range of the turbo. It is way to big in my opinion- I put down maybe 180/185 hp/tq up here in colo spgs (6400ft). I t3t4 would be much better down the line. What turbo are you guys running? Next time you order pistions I may have to give you some $ and order me some to.
Thx, K
I am doing the tuning for 3 different engines, we use T25G's, rated 250 hp each, so we are running a tad over the rating, but i have been told they will supply air for 330 hp each.
The second engine is a stocker with Argo rods an CP pistons, the same turbos but with larger compressor cover, and it puts out 305hp at the wheels @ 14 psi.
The 3rd engineis built much like ours, with rods, pistons, cams, GT35R turbo and makes 365 at the wheels @12psi.
The 2nd and 3rd engine use a factory intake manifold, with the air valves removed, and a lage plenum box welded on . We use the custom made plenum, as shown in the photos.
I will have to get the Job number for the CP pistons the other guys use, as we spec'ed 0.927" Chev piston pins for our setup, as it was stronger, and we could get a high quality tapered lightweight pin, which was less weight than 0.866" pin the honda uses. The other guys elected to use the standard size pin. Of course this meant we had to spec our rods for 0.927 little end.
Can you let me know the specs of that T4 turbo, and what ecu you are using ??
Chris
Old 06-09-2009, 12:09 AM   #2
Telion
Don't doubt it!
Originally posted by BUZZARD
Turbo's are great altitude compensators, thats why they work so well on aircraft. At 6800 ft the barometer is going to read a fair bit below sea level, but the turbo makes up the difference.
Chris
Originally Posted by Dethred
Could it be because you're only running 5.8psi at that altitude?
That is a t4 with external gate ???
Yes, i am sure we could make you a manifold, not sure of the cost. As for benifits, we didnt dyno a stock inlet so it is hard to say.
We run an australian made Autronic ecu, and i am the Newcastle dealer for them.
What is an FMU????
We ran a stock engine , it is engine #2 in a previous post, and made 185kw/248hp on 10psi boost, with the boxed up plenum. I dont think you are too far from where you should be at that boost. Any chance of posting the dyno sheet??.
What is driving the car like, turbo engines normally have wide flat torque curves, is this the case.
At around 6800 rpm we ran into problems misfiring withthe stock coils, we were making 305hp. This was using an autronic cdi. Have you experienced any misfiring. Engine #2,#3 used a ford 6 cylinder waste spark coil, off a local ford falcon, with the autronic cdi. The engine builder considered our distributor as "old hat, old technology" I wont tell you how much heartache they had trying the std coils, but it was plenty.
I would think an A/R of 0.80 - 1.00 would be more suitable for that engine, fit a pressure guage and measure the pressure between the engine and turbo. This can be done by drilling and tapping 1/8 npt on the turbo or manifold flange.
Use a 1/8 npt compression fitting, some thin metal/copper tube and a suitable guage. Make your metal tube long to dissipate the heat.
You are looking for a ratio of 1:1 or better , that is for 5 psi boost you want 5 psi or less backpressure.
Yes, it is externally wastegated up to .5 bar now. The car pulls very hard for the altitude, but the faster I go the harder it seems to pull. I am sure I have ex. leaks in the system, and the piping job is less than desirable-it kills my spool up time I am sure. I was able to pull a 350 Z from a roll on 5.8psi. An FMU adj. the fuel pressure 1lb per psi to richen the mix for the turbo. A cheap way out from injectors and a good fuel mgmt. system. I dont think I am missing on any cylinders, but then again I am only running to stock redline. I dont make power beyond that anyhow so it would not be benificial until I installed a cam. Do you have a large cam in you engines? There is a dyno sheet in the dyno post above this.
Kyle
We run mild cams, and you may have read me talking about our bank to bank problems with the cams. If you are going to get cams, MAKE SURE that they are the same on each bank. I think if i was doing another set of cams, i would try WEB cams inthe US.
Can you put a link to that dyno sheet, i cant find it.
The cams really help the engine at high rpm, on our #1 engine we are using 7800rpm redline and it pulls all the way to it.
I have heard that the type 2 cams are different,is this the case ?? Will someone send me a set so i can measure them ???
We are only seeing type 1 engines over here in AUS, as we only get JDM engines from the importers.
Good luck.
Chris
Old 06-09-2009, 12:54 AM   #3
is it just my pc, I get a error message when trying to view the pics?
Old 06-09-2009, 12:58 AM   #4
Russian
Russian's Avatar
Russian will become famous soon enough
I think the pics are just old, dead links.
Russian is offline   Reply With Quote
Old 06-09-2009, 12:59 AM   #5
oh okay, thanks.
Old 06-09-2009, 10:12 AM   #6
Telion are those pics supposed to be of the turbo buggy? If so I have them somewhere.
Old 06-09-2009, 02:51 PM   #7
picky no showy
Old 06-09-2009, 07:52 PM   #8
Telion
Don't doubt it!
Pretty sure they are can you update it I can't seem to locate mine and think I might have lost them.
Old 06-09-2009, 10:15 PM   #9
Jonslegend
Ive Got 2nd Gear!!!!
Jonslegend's Avatar
Real Name: Jonathan Roose
Jonslegend will become famous soon enough
ok im hearing not 56k friendly alot. what the heck does it mean
It's not Gold, It's Cashmere
Jonslegend is offline   Reply With Quote
Old 06-09-2009, 10:25 PM   #10
sap
ignore the smoke
sap's Avatar
Send a message via AIM to sap
It means there are lots of pictures, thus you won't want to open the thread if you're on dial-up.
Sig by Cole Austin
RIP Fut RIP l4zy
