Old 06-26-2012, 08:17 PM   #21
Ken
ridin' high
Ken's Avatar
Send a message via AIM to Ken
ssr fins whaddup!
. k e n
Old 08-13-2012, 06:54 PM   #22
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
So whats the reasone the shims had to be placed? I didnt understand why.
Old 08-13-2012, 07:19 PM   #23
Eggman
Eggman is on a distinguished road
the spacing from the notch (for the fork bolt) and the step is larger on the accord. if you didn't use a spacer, you wouldn't be able to put the bolt thru the fork. hard to explain without pics.
Eggman is offline   Reply With Quote
Old 08-18-2012, 03:58 PM   #24
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
Oh ok thanks i think i got it.
Old 09-02-2012, 11:21 PM   #25
eden12
Desert Cali Legend
eden12's Avatar
Real Name: chris
eden12 is on a distinguished road
Send a message via Skype™ to eden12
love that oldskool look, btw can that be done to our g1 sedans 87's? n how can it be done? thanks
eden12 is offline   Reply With Quote
Old 09-03-2012, 12:01 AM   #26
It's harder to do it on our Sedan (86-88) because of the rear spring design.
Old 09-03-2012, 12:36 AM   #27
eden12
Desert Cali Legend
eden12's Avatar
Real Name: chris
true, because of our separate spring n shock suspension, so what do u suggest, or how can we drop our cars from the rear, i've done the front but rear is difficult
Old 09-03-2012, 02:26 AM   #28
I'm using Intrax Lowering Springs. But they are really difficult to find nowadays. They usually go for around $250.
Old 09-03-2012, 06:35 PM   #29
TJcars2
The Mad Scientist
TJcars2's Avatar
Real Name: Taylor
TJcars2 is on a distinguished road
You could possibly use front coilovers in the rear if you swap the top hats.
I'm on Prelude lowering springs from Intrax with the front springs in the rear and the rear springs in the front. The front springs (Now my rear springs) Are really soft, hence the reason I swapped them around.
No one's ever gotten noticed from catching the small fish.
TJcars2 is offline   Reply With Quote
Old 09-03-2012, 06:47 PM   #30
3GCVC
Quest for the Ti...
3GCVC's Avatar
Real Name: Alex
3GCVC is on a distinguished road
Send a message via MSN to 3GCVC
You want to use "struts" in the rear as its mac-strut type in the rear and the shock carries all the load and holds the alignment true unlike the front end where it does not. If you put the front shocks in the rear the shock shafts could bend as the shock shafts arent large enough diameter to prevent bending etc.
I think the rear needs something from a S13 / S14 silvia front. Get a pair of "full-tap" front coilovers remove the springs and have an adapter made to suit the Legend hub which spins onto the bottom of the full tap threaded silvia strut, which I assume is just a "clamp on cup" style ie very easy to make the adapter.
AE86 rear coilover springs & adjuster which should fit straight onto the Legend rear lower control arm would complete the height adjustability in the rear. (may need to play with spring length and spring-rate however.)
Anyone understand what im on about?
3GCVC is offline   Reply With Quote
OEM spg rate / Ebay Coilovers, Accord, TSX, Prelude or other Suspension? wadd3456 2nd Gen. Legend Performance Enhancements 2 01-04-2011 06:39 PM
FYI: Bose Speakers The Crowing 2nd Gen. Legend General Discussion 19 07-01-2010 02:39 PM
FYI: AC compressor rebuild Espada 2nd Gen. Legend General Discussion 1 06-21-2010 06:06 PM
98-02 accord coilovers, will they work?? antbo 2nd Gen. Legend General Discussion 3 10-10-2009 03:01 PM
D2 Racing coilovers vs Ksport coilovers? spcgloc Wheels & Tires 18 09-24-2009 09:06 PM
