Old 06-05-2009, 12:54 PM   #1
Ken
ridin' high
Ken's Avatar
Send a message via AIM to Ken
Default Make Your Own Amber Corners
Originally Posted by Ken
I've been meaning to do this for a while already, but I haven't gotten a chance to until now. Some of you have seen my full dark amber corners on my G1:
Well, doing it is very easy with minimal costs.
These are the simple supplies I used:
(rubbing alcohol to clean the corners, a foam brush I cut up to fit the bottle of paint, and a bottle of tamiya transparent orange paint that i got at my local hobby shop.)
Step 1: Remove and clean the corners with the rubbing alcohol. This should be easy enough without a picture. Cut foam brush to fit the bottle of tamiya paint, or you can just pour the paint into something else easier to work with.
Step 2: Place the cleaned corners infront of you and open the bottle of paint. Dip the foam brush into it and apply the paint onto the corner in a horizontal motion. One slow and careful sweep is good enough. Try not to overlap the paint when you sweep the coat underneath the first coat of paint. After applying the first coat to the entire corner, it should look like this:
Here is the first coat on compared to the original corner:
Step 3: Place the corner in front of a heater or let it dry for a few minutes before applying second coat. This would be the perfect time to do the other corner.
Step 4: With the corners not fully wet anymore, its time to apply the second coat. Repeat steps 2 and 3 for the second coat. It should look like this:
Step 5: Repeat steps 2 and 3 until you have reached the 4th or 5th coat (or until desired darkness of the amber).
After 3 coats:
After 5 coats:
Step 6: Let it dry for a few hours or overnight and reinstall it onto your car. You can wet sand lightly with 2000 grit sandpaper if you are not happy with the texture of the corners. Mine don't look that great, but its good enough. I want to replace mine in the future since my current ones are cracked from age.
Heres a few pics of how mine look the morning after I finished them:
. k e n
Old 05-17-2010, 02:24 PM   #2
89Legendary
89Legendary's Avatar
89Legendary is on a distinguished road
wow this is pretty nice bro...great idea..so a local hobby shop should have this amber paint huh?how much it cost you to buy this paint?
89Legendary is offline   Reply With Quote
Old 05-17-2010, 09:37 PM   #3
Vipstats
Vipstats's Avatar
Real Name: Chris
Vipstats is on a distinguished road
2 Bucks per bottle here in NY.
Vipstats is offline   Reply With Quote
Old 05-19-2010, 03:59 PM   #4
89Legendary
hey Thanks Bro!! This is a great idea...look pretty sick JDM style!!!Check out mine.
Old 05-19-2010, 07:00 PM   #5
Not bad, but I hate amber lol.
Old 05-25-2010, 09:59 PM   #6
Ken
ridin' high
Ken's Avatar
looks good man! I need to paint another set I have laying around since mine are straight up missing a chunk. haha but I've been saying that for the last half a year since I've been too lazy.
. k e n
Old 12-25-2014, 11:27 PM   #7
AcuraLegend55k1990
{Legend}{Supporter}
AcuraLegend55k1990's Avatar
Thanks man could I paint them green I'm in the north east u think if have a problem if I did that
A C U R A _ L E G E N D
S u p p o r t e r
