Old 09-18-2019, 05:05 PM   #1
Triaque
Triaque is on a distinguished road
Default Code 5 Loss of Vaccum At WOT? Help
Hi
My '92 Coupe accelerates awesome. As I wind the engine toward 6000RPM in third gear the check engine light comes on and I smell a flood of catalytic gas and the engine acts as if the ECU went into emergency limp mode. I am usually rolling down the road about 60mph and turn the ignition off and crank the engine a couple of seconds later. The engine cranks right up and so continue normal driving with no issue.
DOES ANYONE KNOW WHY I KEEP GETTING A CODE 5 AT HIGH RPM ACCELERATION???
Much Thanks!!!
Triaque is offline   Reply With Quote
Old 11-07-2019, 06:56 PM   #2
Triaque
This problem still exists after rigorous vacuum line comparison to the routing diagrams to verify correct connections, after a brand new MAP sensor.
Does anyone have any info on this???
Old 11-08-2019, 02:17 AM   #3
4HondaOwner
Premium Gas Only
4HondaOwner's Avatar
Real Name: Kevin A
Why are you driving your car like that?
11-1-2019 * 94 LS Coupe 6 Speed 334,654 miles * October 2019 miles driven = 1,004
Old 11-08-2019, 02:36 PM   #4
Because - Legend!
Old 11-25-2019, 06:55 PM   #5
Triaque
Hi,
If anyone can help with this I would greatly appreciate it. I know enough to properly rebuild the manual transmission in this Legend, and I have with my younger brother in his shop about 4 years ago with the last parts available through Acura...…. but this issue has me stumped.
I'm really shocked that no one on here knows how to diagnose this.
Thanks!!!!!
Really at a loss here :/ tfitz 2nd Gen. Legend General Discussion 6 01-02-2014 12:09 AM
Power/torque loss after code 8 - help! LEGO 1st Gen. Legend General Discussion 48 08-21-2010 10:50 AM
Modifying vaccum to VIS Vic Cardenas 2nd Gen. Legend Performance Enhancements 20 05-24-2010 08:52 PM
Looks like another sad loss Olikado 2nd Gen. Legend General Discussion 15 03-23-2010 04:51 PM
Im at a loss :I smokinfastlegend The Water Cooler 29 09-26-2009 03:26 AM
