Notices
Old 07-22-2010, 03:57 PM   #1
Bacon
Bacon's Avatar
Real Name: Brett
Bacon will become famous soon enough
Send a message via AIM to Bacon Send a message via Skype™ to Bacon
Default Where to put this lil' guy?
I bought a Thermometer on clearance at Target today. It works great, but the cord for it is really long. Here is how I had it set up before:
When I had it this way (for only ~1 hour), it made little dents in the driver's door panel. I immediately removed it. Even if they are dents I can't see unless the door is open, they need to not be there. Where can I mount this (with the sensor outside the weatherstripping, in the door jamb) that will hide the wire, and not cause dents in the door panel?
Also, for those with LS's or GS's, what switches go in the area I mounted my thermometer?
Bacon is offline   Reply With Quote
Old 07-22-2010, 04:01 PM   #2
Slix
That One Guy
Railway Line Champion
Slix's Avatar
Slix is on a distinguished road
looks like you have plenty of wire attached, just run it somewhere thats not noticable. Drill a hole where you have the actual therm mounted and run it through the firewall like you would an aftermarket alarm
I gotta have me more boats and hoes!
The Nina, the Pinta, the Santa Maria
I'll do you in the bottom while you drink a Sangria
Slix is offline   Reply With Quote
Old 07-22-2010, 04:01 PM   #3
Captain Slow
Captain Slow has a spectacular aura aboutCaptain Slow has a spectacular aura about
What are you measuring? A/C, coolant, oil? The switches there are for the courtesy dimmers on the floor, fogs and traction control.
Old 07-22-2010, 04:32 PM   #4
Bacon
Bacon's Avatar
Real Name: Brett
I want it to not be permanant
Just the outside temperature and interior temperature.
Old 07-22-2010, 07:43 PM   #5
Xclusive
Xclusive's Avatar
Xclusive is on a distinguished road
You could get aftermarket rearview mirror for outside temp. Not sure if they have one for inside temp.
Xclusive is offline   Reply With Quote
Old 07-22-2010, 09:07 PM   #6
94legendcpe
Junior Cheeseburger
Trampoline Tricks 2 Champion Extreme Pinball Champion
94legendcpe's Avatar
94legendcpe will become famous soon enough
Cut the cord? Sounds simple enough. Just cut it and solder the wire(s) back together and there you have it.
94legendcpe is offline   Reply With Quote
Old 07-22-2010, 11:33 PM   #7
Legend37
Legend37's Avatar
Real Name: Sam
Legend37 is on a distinguished road
Ding ding ding. We have a winner!!
Legend37 is offline   Reply With Quote
Old 07-22-2010, 11:36 PM   #8
Bacon
Bacon's Avatar
Real Name: Brett
Well, it would be easier if i had a soldering iron.... or knew how to solder
@ me.
Aggression, in its most elegant form.
Old 07-22-2010, 11:38 PM   #9
The one and only
don't put that thing where momma's used to in the 60's!
but u can put it where u have it i think is best or right above the radio, it looks the same size as my turbo timer
9/12/10 9:02pm The rebuild begins
2/8/11 8:09pm Engine reinstalled
Old 07-22-2010, 11:59 PM   #10
Bacon
Bacon's Avatar
Real Name: Brett
Hahaha
I figured out a way. I'll post pics tomorrow. Do you know of any clear tape that's meant to stay somewhere for a while when you stick it on?
A Lil Update on Jessica!!!!!! 56K please upgrade. Jonslegend Second Generation Legend -- 1991 - 1995 17 05-05-2010 11:43 PM
I hate stupid lil Humans SPARTACUS The Water Cooler 16 03-02-2010 12:40 PM
Put ya flags up! Fatal The Water Cooler 24 10-13-2009 03:02 AM
Put the pedals in Jonslegend 2nd Gen. Legend General Discussion 18 10-09-2009 06:35 PM
Put new Cluster cover in but... LegendarySE 2nd Gen. Legend General Discussion 34 06-19-2009 09:37 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
