9Legend3
Ive been searching and searching and ive seen alot of talk about porting and polishing. I just cant PM everyone whos done it and ask all the questions id like.
I plan on P&P my heads and Type2 intake manifold but im just curious to know if and or what il be needing to do after that? Can i run it as is even after P&P or will i have to run dyno tests and tweek the computer, thats what im guessing id have to do but it'd would sweet if someone could give me some good advice or info. Also if anyone knows the best way to go through with this project? ![]() ^60k oringial miles 1993 Acura Legend LS Type 2 coupe
Acura Advance |
Type II King
well it depends on how much money you want to spend, port and polishing is going to do very little if you don't have other supporting mods.
If your going to go through all the hassle of taking off your heads as well as the intake manifold to have them p&p, its worthless unless you have an aftermarket air intake and some sort of free flowing exhaust (2.5" tubing). I would start with those mods first. Then get your self an SR5guy chip to better utilize these modifications (search this forum for more info on the chip). Those are just some mods I would get before p&p anything.
custom 2.5" mandrel exhaust, CAI,web cams, comp cam valve springs, p&p heads/manifold, tb bypass,egr block, 5spd clutch/fly, 80a mounts, type 1 pulley, headers, custom y-pipe, SR5guy Chip, 6spd, strut bar, F/R sway bars, FL tie bars, ksports 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.657 1/4 mile @ 101.861 mph & 1.934 60' NA |
#3 | |
9Legend3
My other mods are Weapon R intake... Type2 intake manifold... OBX hearders with the test pipe.. and then 2 3/4 exhaust out to the back, Magnaflow muffler. Then i have a Venom Chip, and Lighten Pulley. So this is why im pushing for this project.
Acura Advance |
#4 | |
Life Ruiner
Get yourself on a dyno and have the AFC tuned. IMHO, I would spend the money on a 5spd clutch kit converstion, or WEBcams than the P&P. ~Dv8
10.5 yrs and counting. AEM EMS Powered. To many Experts, not enough Results. Where are yours? 448WHP@6750RPM 366wtq 10PSI 07/09 12.953@107.865MPH 06/07 95 deg. 234whp 229lb-ft 13.7@99mph 95 deg. N/A 06/07 G35c-VSC 12.776@109.01MPH Go-Kart 35whp 29wlbft http://www.2slik4u.com/ My Garage Buy Custom Legend Exhaust/Remus |
#5 | |
9Legend3
Thank DV8 Im going to look into this.
Acura Advance |
Super Duper Member
The work I did on my heads and intake seemed to have performed quite well. A lot of my work was gasket matching and smoothing more than porting and polishing. You need good titanium carbide grinding bits ($170-200) and a P&P sanding kit ($20-40).
I looked up a few different methods online, I can find them if you're serious about doing it. |
#7 |
if you are looking for power Forced Injection is the way to go. Might be a bit more expensive but well worth it. its very expensive to get additional HP out of a N/A 3.2 or 3.5. Trust me!!
1994 Legend Coupe 6 speed |
#8 |
^ I assume you mean forced induction, Legend are already injection, and anyways dumping more fuel into the cylinders would just make it run rich. Force induction will cost you several more thousand than 1, I assure you that much.
#9 |
Type II King
honestly, i didn't spend very much getting my car into 13's NA haha if you have a good plan and don't waste money pointlessly its not very expensive to make the legend pretty quick. A must have are webcam regrinds, intake, exhaust and chip. With the mods I have, I still beat the 1/4 mile times of most members on this forum that run nitrous. Sure a turbo legend would be faster, if properly made but that route actually tends to be more expensive. Turbo, piping, bov, intercooler, aem ems, injectors, o-ringing the block, custom headers/exhaust, and tuning just to name a few things, all that is going to be quite a bit more than all the money I spent on my car. I guess it really just depends how fast you really want to make the legend, or if you'd be satisfied with 13's.
#10 | ||||
9Legend3
NOS isnt what i had in mind... Ive seen alot of ppl blow there motors, and im sure doing it right you wont but i dk if id even feel comfortable taking the chance.
Acura Advance |
| Thread Tools | |
| Display Modes | |
| 3 hr project | whats77inaname | 2nd Gen. Legend General Discussion | 40 | 09-15-2009 07:42 AM |
| Project 97 3.0L CL | Acura2g | Other Cars | 30 | 09-12-2009 12:51 PM |
| Project Complete! | forevralegend | 2nd Gen. Legend Performance Enhancements | 33 | 08-12-2009 12:55 AM |
| Project Ka7 | Dance4Zak | The Water Cooler | 12 | 06-30-2009 10:04 PM |
